Valve spring ?
Old Nov 19, 2013 | 07:27 AM
bada's Avatar
bada
Default Valve spring ?
I understand that the valve springs, on the C5 Zs, have a problem breaking. Will the springs off a 2008 LS7 ZO6, work on the C5 ZO6s? If so is there anything that, needs to be changed to make them work?
Old Nov 19, 2013 | 11:33 AM
JetMechZ16's Avatar
JetMechZ16
There is a post about what vins and years were affected by this, it may be in a sticky. I believe the years were 2002- early 2003.
Sorry but don't know anything about the ls7 springs.
Old Nov 19, 2013 | 12:16 PM
vettenuts's Avatar
vettenuts
I was under the impression that the LS7 valve springs have much different installed heights and free height. You should get the spring specifics to figure out whether they will work.
Old Nov 19, 2013 | 02:28 PM
racebum's Avatar
racebum
since a full set of new ls6 springs is $65 why even chance it?
the ls2/3 spring is the compatible one
which is what the new ls6 springs are
Old Nov 19, 2013 | 03:55 PM
Mattie Num Nums's Avatar
Mattie Num Nums
Why not just get a good set of aftermarket springs?
Old Nov 19, 2013 | 04:08 PM
racebum's Avatar
racebum
why waste more money if you're not running more cam that require it?
failures of the new spring type are virtually non existent
Old Nov 19, 2013 | 09:59 PM
onlyavette's Avatar
onlyavette
What is the new spring type?
Old Nov 21, 2013 | 11:55 PM
T-TOP TOM's Avatar
T-TOP TOM
Do you know the part # for the springs? Where can you get a set for $65? Thanks Tom
Old Nov 22, 2013 | 01:04 AM
racebum's Avatar
racebum
12499224
is the part number for 16
jegs, pace performance and summit all carry them for 60-65 a set
http://www.jegs.com/i/GM+Performance...FVGCQgodmCMAIA
59.95 at jegs and apparently with free shipping
Old Nov 22, 2013 | 01:05 AM
Mattie Num Nums
I just figure its one of those things where it won't cost a ton more to not have to worry about it again. Only thing I hate is my car sounds like a pissed off sewing machine.
Old Nov 22, 2013 | 02:55 AM
racebum's Avatar
racebum
that's really not true though. pac springs have broken, comp springs have broken. there is no perfect solution
if you have more cam and need more spring then you use more pressure. if you don't not only is it a waste of money it also robs hp and puts more stress on the lifters if you up the spring pressure
some guys just get it in their head stock sucks and want to mod everything just to say it's "better"
the failure rate of the new gm springs is virtually non existent and they are used in all ls2 and ls3 cars. think about how many cars that is
To Valve spring ?
