Looking for a cam
Old Nov 21, 2013 | 12:14 AM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
Default Looking for a cam
Good all around cam for a stock automatic c5 with 3.42 gears and a 3400 RPM torque converter C5 that will have plenty of torque and pass CA smog test with flying color
Old Nov 21, 2013 | 09:41 AM
Josh@SpartanLSX's Avatar
0Josh@SpartanLSX
Former Vendor
You'll want to have a little bit of negative overlap to guarantee you'll pass the Cali sniffer.
Something like a 220/224 .595/.585 115LSA camshaft would pass and provide plenty of "off idle" torque. Would peak around 6200.
Seeing as installing a camshaft in a C5 is an expensive and time consuming effort you'll want to stay more on the conservative side to ensure you don't have to change cams twice because of a failed emissions test.
Old Nov 21, 2013 | 10:29 AM
Kreeess's Avatar
Kreeess
you should really hit up my mechanic/tuner he can answer all your questions.. and give you pricing options as well
Old Nov 21, 2013 | 11:48 AM
zeevette's Avatar
zeevette
The "Tony Mamo" cam was designed to work in CA., and it's 224-228 @114. A good tuner is important, too.
Old Nov 21, 2013 | 08:11 PM
PRE-Z06's Avatar
PRE-Z06
and about as big as you want to go.
To Looking for a cam
