Small oil leak
Nov 23, 2013 | 01:57 PM
Small oil leak
I have a small oil leak drip coming from the pictured location. Any ideas to what this could be?
Nov 23, 2013 | 01:58 PM
I should mention it's on the front passenger side of the intake.
Nov 23, 2013 | 02:06 PM
Nov 23, 2013 | 02:21 PM
yep, pcv valve. it's not "technically" an oil leak as the oil is being sent back through the manifold to be burned off per emissions. More-so a vac leak. May need a new hose, may need a new PCV valve ($5), or you may just need to seal it off better.
Nov 23, 2013 | 02:30 PM
That's the pcv valve right there? Though it was at the back drivers side.
Nov 23, 2013 | 02:31 PM
And how would I seal it better?
Nov 23, 2013 | 11:11 PM
Sealing PVC valve
Quote:
Originally Posted by
guido7834
Black silicone RTV?
Nov 24, 2013 | 07:10 AM
Thanks.
It seems to be leaking from where the metal clip that holds it enters the rubber boot that holds the pcv valve. I'll see what I can do with it.
Nov 25, 2013 | 08:10 PM
If I decide to replace the whole hose assembly, does the intake or anything else need to be removed?
Nov 26, 2013 | 01:46 PM
guido7834
It's tricky, but you can replace the entire hose assembly without having to take anything apart first.
Nov 26, 2013 | 03:55 PM
Nov 26, 2013 | 05:11 PM
guido7834
OK, Thanks.
Pay close attention to how you get the old one out so you'll know how to weave the new one in.
Nov 26, 2013 | 06:47 PM
gotcha!
