might search car-part.com.. I didnt see any ECU (Engine Control Unit) listed but if you search 1997 Corvette and find another part, they may have the the ECU. You will need to have them reflashed to your car by the dealer. then you have to relearn the ECU to your security key. 1996, 1997 and 1998 where weird years for GM computers.. they changed a little each year in the early OBDII years which makes them hard to track down. Might check Rock Auto.
I doubt that you have a PCM failure, however, until you post a complete list of PCM DTCs that you obtain by reading them through the DIC, it is difficult to be positive or to provide any helpful guidance.
If it were me, I would get the car out of the STEALERSHIP and allow us to LEAD GUIDE AND DIRECT!
Bill
Do not ever rely on a stealership. I found a very competent shop and he fixed numerous electrical problems including a new BCM for 650. I will bet Bill and Sam will be able to help you with once they have codes. They know more than most dealers. They helped me immensely. I just wanted a skilled tech to do the actual work.
David had a bad BCM, his guy got a GM rebuilt and programmed it for his Key and options. I think the BCM was about $170 and some change for programming. I am sure he could test your PCM if you mailed it to him and if bad provide you a good tested one at minimal cost. I am thinking about having his guy get me a PCM and BCM and test and set them up for me to have in the future if I ever need to use for diagnostics or replacement on my car. I plan to have him do this and then ship them to me even though he is only 2 hours away in Charleston SC.
With that said, Bill is correct, we need to determine what IS the problem before you start throwing more part and money at the issue.
This question is really only because I am curious about this, I did not realize the new computers had to be programmed to the cars, till reading this thread.
If he found someone local with the same year car, could it be swapped over to test or would it still need programing?
The PCM needs to have an operating program and tune Flashed into it for your year car.
Then,, It needs to be LINKED to the BCM. Its called a hand shake to satisfy the security protocol.. You can do it with a TECH2 or in an emergency, follow this procedure:
BCM/PCM RELEARN PROCEDURE
You will need to conduct the PCM/BCM relearn process. This matches their handshake ID's and allows them to talk to each other.
Do this before you worry about VATS issues:
1. Turn on the key for 11 minutes.
2 Turn off the key for 30 seconds.
3. Repeat 1&2 two more times.
4. Turn on the key for 30 seconds.
The car should start and run with the new BCM. Good luck and report back on your progress.
Shirl
SD Racing Enterprises
Aguila, AZ
Coutersy of MrEracer
So who is Davids guy that may be able to test my PCM?
David is a friend of mine. If you PM or email me with your phone number I can discuss our contact for module testing using a Tech II. This guy is so good he started his own business and is not expensive.
You posted the PCM looked corroded on the outside but are there any holes in the case? You should open it and take a look at the circuit boards. I've got a '96 LT1 PCM that was in a car fire and the case is all black down one side and it even had chunks of plastic from the holder melted onto it that I knocked off but it still looks perfect inside and it still works fine. The cases are fairly thick and the PCM is pretty tough both mechanically and electrically.
You also posted that there was a MAF code. You need to check out the wiring harness. I would pay close attention to the harness between the MAF and the back of the engine. Many people have had bare wires in the harness on top of the engine rub on the fuel rail or other brackets causing shorts which make the car act-up. You have to un-wrap the whole harness and examine each wire from end to end to check them right.
I could try your PCM in my 98, but my car is put away for the winter and it's staying where it is until spring.
Shirl
Aguila, AZ
Bill Curlee
Sorry Bill, but you cannot swap PCM's from the same year car and expect them to work.
The PCM is tied to the VIN of the car it came out of you would have to reflash the test PCM with the suspected cars VIN and this takes credits from the software like EFI Live or HP tuners.
this guy has one for a 98
I am not sure it will work I am sure one of the more knowledgeable members can let you know. I ran across the link when looking for tips to track down my problems
he asking $90
Umm, no. That's what the VATS re-learn is for.
Might need to program it to set it up for the car (auto vs manual bin for example), but that's completely different then programming the VIN.
Its GMs ultimate diagnostic tool and enables the tech to communicate with the PCM, BCM and see what ALL the electronics in the electrical system are doing. You can also reprogram the BCM with it.
Its very complex and does a LOT of stuff. It is able to turn ON & OFF all the bidirectional controls Example: You can turn on and off the cooling fans or the lights with this unit. It connects to the system thru the OBDII port.
With a CAN D adapter module, you can communicate with C6 vehicles.
Ok guys thanks for all the responses. I'm planning on going back over this thread and the PMs and decide my next move. I still haven't been able to locate a used one.
I took mine apart, everything looks fine, didn't see anything burnt or melted.
Whats the easiest way to post pics?
$170 right off the shelf at a local NAPA auto parts store. GM certified remanufactured and warranted. My tech programmed it for my options. All was well.
Dave
