thermo shim
Jul 8, 2002 | 07:03 PM
thermo shim
Does anyone know the diameter of the stock needed to modify the thermostat opening temperature?
Jul 8, 2002 | 09:52 PM
Cruise-In VII Veteran
Re: thermo shim (jfpilla)
.101 is for 180*
:cheers:
Jul 9, 2002 | 03:52 AM
Re: thermo shim (RPOZ4Z)
Any how to links on this mod? Thanks!
Jul 9, 2002 | 03:12 PM
RPOZ4Z, If .101 is the diameter, what is the thickness? I am looking for this value too.
Jul 9, 2002 | 03:24 PM
Re: thermo shim (ace)
http://nospam.com/modstat.html
Wow, this is the first time I've been automatically censored! :crazy:
Oh well, try this and remove the spaces. Regardless of the censoring, it's a good how-to:
w w w. t e a m z r 1 . c o m /modstat.html
[Modified by WhitneyR, 2:25 PM 7/9/2002]
Jul 9, 2002 | 03:35 PM
.101 is the thickness. Would like to know the diameter. This link gives instructions on making the shim, but doesn't give the shim diameter. I would like to make a shim before I take off the thermostat.
http://www.ls1info.com/article.php?sid=180
[Modified by jfpilla, 2:46 PM 7/9/2002]
Jul 9, 2002 | 04:24 PM
Whoops! you're right.
checkout the Team ZR1 website for directions.
Jul 9, 2002 | 04:44 PM
There is a link in my post to the instructions. Don't see the stat shaft diameter.
Jul 9, 2002 | 05:45 PM
just measure the shaft on your thermostat when you take it out. :cheers:
Jul 9, 2002 | 05:59 PM
Per my 2:35pm post. It would by nice to have the shim made ahead of time. Would save having to find the right stock after removing the stat.
Jul 9, 2002 | 06:05 PM
Whew! tough crowd... :lol:
Jul 9, 2002 | 09:49 PM
Found it. The shim diameter is 3/16.
