Forum thoughts ?
Old Dec 2, 2013 | 07:13 PM
04tripleblkcoupe's Avatar
04tripleblkcoupe
Default Forum thoughts ?
Been kinda thinking of getting a LSX 454 and replacing my LS1 heads and cam motor. Has anyone else went this route and if so your thoughts ?
Old Dec 2, 2013 | 11:16 PM
NukeC5's Avatar
NukeC5
If you have the $$$, have at it
Old Dec 3, 2013 | 05:14 AM
vettenuts's Avatar
vettenuts
I wouldn't like the extra weight (isn't that an iron block) and would go down a path with an aluminum block.
Old Dec 3, 2013 | 07:31 PM
04tripleblkcoupe
Well the way I look at it GM provides a warranty, and most engine builders I have looked at really doesn't have any type of so called warranty.
Old Dec 4, 2013 | 03:25 AM
Ohyoufan's Avatar
Ohyoufan
A buddy of mine from my hometown has an LSX 454 in his 05 GTO. Made 580 rwhp with 1 3/4 headers and believe he hit 600rwhp with 1 7/8. The thing pulls like a freight train. Don't like the idea of putting an iron block in in place of aluminum, but it can't be any difference weight wise than doing a pro charger right??
Old Dec 4, 2013 | 04:56 AM
vettenuts's Avatar
vettenuts
How about some of the other turn key motors they have in the GMPP catalogue? My dream was always the C5R block.
Old Dec 4, 2013 | 09:43 PM
04tripleblkcoupe
Well what I was thinking is that as the speed gets higher the added weight would help with front end being so light plus having added power.
Old Dec 5, 2013 | 10:26 AM
Nowanker's Avatar
Nowanker
Pro Mechanic
Sweeeeeet! I'd pass because of the extra weight (60lbs?), but in the context of a 3200 lb car... Move the battery into the back and the weight distribution stays the same. Currently piecing together a 4.125" stroker/LS7 block. Had all the parts ready for balance and found they sent me a 4.100 crank instead. Stupid ebay!
Old Dec 5, 2013 | 03:33 PM
PRE-Z06's Avatar
PRE-Z06
Are you having a GM dealership install it? I would think it'd be hard to get a performance part warrantied with all the fine print and when bad tuning can ultimately kill any engine, as nothing is bullet proof...
http://www.crateenginedepot.com/Webp...?WebpageId=199
Old Dec 5, 2013 | 05:44 PM
zeevette's Avatar
zeevette
Cool. Are you getting the one that sticks the tunnel ram through the hood?
Old Dec 5, 2013 | 10:47 PM
baxsom's Avatar
baxsom
I put their ZZ454 into my 72 stingray and that thing is a monster.
Old Dec 6, 2013 | 09:00 AM
04tripleblkcoupe
Well looking into doing a 408 ci. close to the same price and alum block.
Old Dec 6, 2013 | 12:52 PM
1999corvettels1's Avatar
1999corvettels1
I say go for the ERL 454 short block, put some good heads on it, might be in the same ball park, however you have a aluminum block with heavy duty sleeves.
That's what I wanna do.
Old Dec 6, 2013 | 12:58 PM
1999corvettels1
Old Dec 6, 2013 | 03:01 PM
corvettebob1's Avatar
corvettebob1
When I got my ProCharger I weighed the box and all it was 70lbs now that extra weight is producing over double the HP of the stock 347.
And can be turned up with just a pulley change and tune, try that with a N/A engine.
Old Dec 6, 2013 | 03:07 PM
zeevette's Avatar
zeevette
Maybe they can stroke the block out to 550 C.I.
Old Dec 6, 2013 | 10:13 PM
MPM IV's Avatar
MPM IV
I went with a 440 based on an LS7 block. It made 600 RWHP off the bottle and has been rock solid since 2007.
On occasion when that isn't enough it makes a little over 800 on the bottle.
There are better ways to keep the front end down than adding weight.
Old Apr 8, 2014 | 05:27 PM
Lpe403's Avatar
Lpe403
I have an LSX 454 in my 99 vert thats puts down 635 rwhp on 91. The car has been lowered and with grippy 295 Toyos up front I can turn on a dime. I notice no penalty with the added weight of the iron block. The car handles great and with Eradispeed cross drilled and slotted rotors stopping is no problem.
I have a rowdy setup, but I never intended this to be a DD. The 454 provides a singular experience. The next step is going to be an E85 tune. I imagine I'll be close to 700 rwhp then.
To Forum thoughts ?
