Vacuum line going to AIR pump
Old Dec 14, 2013 | 11:03 AM
VandykeT/A's Avatar
VandykeT/A
Default Vacuum line going to AIR pump
I'm deleting the AIR system on my 04 Z and while removing it I noticed a vacuum line going to a check valve beside the pump. What is that vacuum line for? I just blocked it off.
Old Dec 14, 2013 | 11:18 AM
Zorlac's Avatar
Zorlac
Not sure of the answer but maybe this'll help.
Old Jan 25, 2014 | 09:44 AM
dr_whigham's Avatar
dr_whigham
I'd like to bump this for an answer.
I as well just blocked off the small vacuum line, but am now wondering if I should have left it open for something?
Old Jan 25, 2014 | 09:59 AM
Corvette_Ed's Avatar
Corvette_Ed
Old Jan 25, 2014 | 10:04 AM
dadaroo's Avatar
dadaroo
That is the air pump shutoff valve. You should plug the vacuum line going to it since you are deleting the system.
Old Jan 26, 2014 | 09:19 PM
dr_whigham's Avatar
dr_whigham
Good deal, as that's what I did. Just wanted a little confirmation on that decision. Thanks!
Old Jan 27, 2014 | 11:42 AM
dadaroo's Avatar
dadaroo
I am sure your picture does not do you justice. If it does, stay out of my neighborhood. Motor on!
Old Jan 27, 2014 | 12:00 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Trace the vacuum line back to it's source, and cap it off there.
That would eliminate the possibility of the unused vacuum line developing a leak, anywhere along it's entire length, in the future.
Old Jan 27, 2014 | 12:16 PM
Rj-lo's Avatar
Rj-lo
so you can just take this whole line out with no ill effects?
I just swapped headers and the passenger side AIR hose doesnt reach. I was wondering what i was going to do about it, but if the whole thing can go away.....
Old Jan 27, 2014 | 03:36 PM
RedZMonte's Avatar
RedZMonte
If you eliminate the AIR system you will need to tune it out (and all related codeds) of the ECU to keep the CEL from coming on. It heats the cats faster on starts mostly to make them burn hotter and cleaner to lower emmissions at startup/idle.
Its kind of a pain in the A to remove, you need to take off the intake manifold and the pump out of the bumper. You will also need some Block plates for your headers (cheap on line if you search)
S
Old Jan 28, 2014 | 08:10 AM
dadaroo's Avatar
dadaroo
S
I assume you removed the manifold just to remove the check valve and tubing back there? It should be able to be abandoned in place and then removed if you ever needed to remove the manifold in the future. Of course removing it should lower your ET, just not sure you could tell by the seat of your pants.
Old Jan 28, 2014 | 02:01 PM
Rj-lo's Avatar
Rj-lo
S
right on. Which codes will it throw?
Old Jan 28, 2014 | 02:57 PM
dr_whigham's Avatar
dr_whigham
P0418 is all I threw. Then again I only drove it an hour to EPS for the tune...
Old Jan 28, 2014 | 07:09 PM
m6 c5's Avatar
m6 c5
I never got any codes with mine removed before I had mine tuned and that was 6 months
Old Jan 28, 2014 | 10:29 PM
dr_whigham's Avatar
dr_whigham
Did you pull the fuses...?
Old Jan 29, 2014 | 06:00 AM
m6 c5's Avatar
m6 c5
Nope, my car had been tuned previously so that may have been part of it but I did the same with my dads 02 z and he never had codes for it either and he went about three months before having it tuned. My car is also an 02 z as well.
Old Jan 29, 2014 | 08:36 AM
dadaroo's Avatar
dadaroo
I only saw 3 codes in my FSM related to this system. P0410, 412, and 418.
To Vacuum line going to AIR pump
