TPMS Question
Old Dec 23, 2013 | 11:31 AM
FRC Carmichael's Avatar
FRC Carmichael
Default TPMS Question
My car had several mods done to it before I purchased it, 1 of them being the dash cluster changed from a 99 base to a 2001 Z06. The previous owner just preferred the look of the Z cluster.
The wheels were also changed but the TPMS were not re-installed.
If I were to look at purchasing the sensors, do I buy the original style or for the 01 Z--which are considerably less money?
Old Dec 23, 2013 | 11:46 AM
jamieo's Avatar
jamieo
They have to be matched to the receiver.If your car is a 99 you will need the early style sensors,later style won't work.
Old Dec 23, 2013 | 11:52 AM
dadaroo's Avatar
dadaroo
The TPMS sensors send their signal to the RFA in the trunk which then communicates the pressure reading via the serial bus with BCM and IPC. I would not think that just changing the IPC would preclude your having to use the earlier sensors since it just displays the info it gets. Worst case you get one later sensor and mount it and see if it will work, or borrow a wheel from someone to test. You cannot tell if it works until you get the car going. I think it is around 20 mph. My bet is that you have to go with the earlier sensors. Let us know what you do and how it works out.
Old Dec 23, 2013 | 12:37 PM
YellowC5Alive's Avatar
YellowC5Alive
You'd need to get the original style ones, check with the dealer https://www.gmpartsonline.net
Old Dec 23, 2013 | 02:00 PM
jamieo's Avatar
jamieo
You can get all 4 for about $140 f you want to use aftermarket sensors.
Old Dec 23, 2013 | 02:08 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I agree with 8vette7 that it is a good time to upgrade to the new style '01-'04. I did that upgrade and it works well. I did it because I wanted the cheaper TPMS for a couple sets of wheels that I swap back and forth, and I wanted new Fobs. If you shop around you can get some pretty good prices. There is even a forum vendor that has the whole set of TPMS, receiver, Fobs in one package. You will need a different connector for the new receiver too.
When you get the new sensors (and/or receiver and fobs if you do the upgrade) you can check to see that they work before they are even mounted. You can train them to the car by holding the magnet to the sensors one at a time while you are sitting in the car and working the DIC to get the programming/training started. If you mount the sensors in the correct wheel for which you tested/trained them, you will not have to retrain them in the wheel. The sensors will read 0 psi and show errors for flat tires until you get them mounted and drive the car so they begin transmitting, or until you retrain them in wheel with pressure.
Good luck.
Old Dec 23, 2013 | 03:35 PM
FRC Carmichael
I haven't seen the that low--do you have a vendor name??
Old Dec 23, 2013 | 04:35 PM
BigGun's Avatar
BigGun
Make sure the sensors will fit your wheels. Maybe that's why they were not reinstalled.
Old Dec 24, 2013 | 11:47 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here are some post that deal with the Tire Pressure Sensor and FOB UP-GRADES!!!
You will be MUCH happier with the newer stuff and its a SIMPLE up-grade. In fact Gene Culley www.gmpartshouse has a complete package that makes it even easier and less expensive.
It involves the Remote Function Actuator, new FOBs and New TPS. Thats it!
Give him a call!
- C5 Tire Pressure Monitor Sys Up-Grade 97-2000 to 2001 RFA System:
http://forums.corvetteforum.com/c5-t...e-sensors.html , http://forums.corvetteforum.com/c5-t...aded-tpms.html
To TPMS Question
