help
Old Jan 8, 2014 | 06:04 PM
Vettes & Checks's Avatar
Vettes & Checks
1st Gear
Default help
uh, my automatic 04 C5 is having transmission problems. I don't usually hit the gas hard at all, but i did today and it would not go into 3rd gear. it would go to 3000 rpms exactly and no higher. what could be the problem..?
Old Jan 9, 2014 | 01:33 PM
BigGun's Avatar
BigGun
If it won't go over 3000 rpm you probably have other problems. A trans problem should not limit your rpm. Pull the codes using the dic and post. This link describes how. http://www.stengel.net/diccodes.htm
Old Jan 10, 2014 | 08:09 AM
n8dogg's Avatar
n8dogg
Check engine light? Were the tires spinning? What happened at 3000 rpm? Did the engine cut off, did it seem like there was a heavy load, any smells, messages on the dash?
To help
