engine squealing noises
Old Jul 11, 2002 | 03:59 PM
jtk30093's Avatar
jtk30093
Default engine squealing noises
I have a 98 A4 with 54,000 miles. I have noticed lately that I have a "high frequency" squealing/whining noise coming from the area in the front of my engine. The noise is most noticable at idle and while driving under 10 MPH. I have replaced the belt tensioner, idler pulley and both drive belts. Has anyone had a bad power steering pump or water pump? If so, what do they sound like when they go bad?
Old Jul 12, 2002 | 10:06 AM
FlaVert's Avatar
FlaVert
Default Re: engine squealing noises (jtk30093)
I've been told that it is the fuel pump, and that it is normal.
Your mileage may vary. ;)
Old Jul 12, 2002 | 11:37 AM
jtk30093's Avatar
jtk30093
Default Re: engine squealing noises (FlaVert)
I dont believe its the fuel pump, it sounds more like a bearing going bad. When I listen very closely I cant tell exactly where the noise is coming from! Can someone please explain to me the correct procedure to "ISOLATE" the noise. I really dont want to take it to the dealer!
PLEASE HELP!!!!!
Old Jul 12, 2002 | 11:41 AM
carpe dm's Avatar
carpe dm
It, of course, could be many things, but have you checked the power steering fluid level? You might have the belt tensioner tested as well. Hope it is easy, quick and cheap to fix. :jester
Old Jul 12, 2002 | 06:42 PM
MDT's Avatar
MDT
jtk30093,
This is a long shot, but may be worth a try: Get a tooth brush and some alcohol and clean all of the little v's on all of the pulleys associated with the serpentine belt. If the belt is bottoming out in the v-grooves because of a dirt/gunk build up, then it will slip, as it depends on gripping the sides of the grooves for traction.
Good luck.
Mark
Old Jul 13, 2002 | 12:40 AM
sbkim's Avatar
sbkim
I have the exact same prob. The dealer replaced the serpentine belt but it didn't help. I still have the annoying high pitched squeak. I think this noise appeared after dealer did the some TSB on alternator. Love to hear some suggestions
To engine squealing noises
