corvette Slipping?
Old Jan 23, 2014 | 03:08 PM
PaulCorvetteGuy's Avatar
PaulCorvetteGuy
1st Gear
Default corvette Slipping?
How much does a rear main seal leak cost to fixed apparently my vette has one. And No idea why my vette is slipping, when I casual give it gas the rmps shoot up but the car doesn't respond well and takes a few seconds to kick in. As I give it gas the oil pressure shoots up to 50 psi and goes back down as I let the gas off, This car is a nightmare please help!!!!!!!!!!
Old Jan 23, 2014 | 03:31 PM
VinnyT's Avatar
VinnyT
So, you have a bad oil leak and your trans is slipping? I'm assuming an auto?
Old Jan 23, 2014 | 03:36 PM
Cutlassmaster's Avatar
Cutlassmaster
If it's a rear main then it's getting on the clutch and causing slippage. Trans is in the back of the car.
Chris
Old Jan 23, 2014 | 04:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please state:
Year car:
People are assumimig that it a MN6 as you stated that the its SLIPPING but A4 can slip also. MN6 or A4?????
Car mileage:
Maintenance history:
First,, If you have weird oil pressure readings, I would bet that you have a defective /leaking Oil Pressure Sensor. That can contaminate the clutch.
I would First replace the Oil Pressure Sensor (OPS) if it is leaking and IF you have a MN6 manual trans, try using some BRAKE PARTS CLEANER and flush out the oil from the clutch flywheel and pressure plate and see if it clears up the issue
(Its a last chance bandaid repair that can help you determine whats wrong)
If you have an A4,, you still need to replace the OPS and thats an entire different troubleshoot and repair process!!
Read and post your DTCs!!!
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine. NOTE! You can read the DTCs with the engine running and or driving down the road but it can distract you. BE careful! Some DTCs clear themselves when you turn the ignition OFF!
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.corvette-web-central.com/C5DTCcode.html
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Bill
To corvette Slipping?
