Differential Weight thingies...?
Old Jan 23, 2014 | 10:53 PM
ccmano's Avatar
ccmano
Default Differential Weight thingies...?
Have to ask, tried search and came up blank. There are these small doughnut shaped weights attached to the back driver side of the differential. Are they vibration dampers or what? What happens if I remove them?
H
Old Jan 24, 2014 | 02:04 AM
Last C5's Avatar
Last C5
Yes, they are vibration dampers. The first thing we unbolt and pitch on track cars.
Old Jan 24, 2014 | 09:23 AM
ccmano's Avatar
ccmano
That's what I thought. How much of a difference is there when it's taken off?
H
Old Jan 24, 2014 | 09:36 AM
NukeC5's Avatar
NukeC5
It was required to remove it when I installed the Pfadt trans mount. Car is fine without it.
Old Jan 24, 2014 | 11:29 AM
Brewmeistergi's Avatar
Brewmeistergi
I believe you'll find the weights are actually there to eliminate driveline harmonics.
Old Jan 24, 2014 | 02:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP!
If you remove it,, you may or may not feel a weird new vibration at specific speeds.
Old Jan 24, 2014 | 11:49 PM
Last C5's Avatar
Last C5
H
Not much if any. You can always bolt them back on if your driveline developes a vibration.
Old Jan 25, 2014 | 09:49 AM
stevenm357's Avatar
stevenm357
Same here... Felt no difference.
To Differential Weight thingies...?
