Instructions for changing Pads
Old Jul 12, 2002 | 09:47 PM
chocoholic's Avatar
chocoholic
Default Instructions for changing Pads
Does anyone have a cheat sheat for changing the front and rear pads or is that obvious that once I whip the wheels off I'm going to be embarassed that I asked? :)
Old Jul 12, 2002 | 10:04 PM
SAXN8R's Avatar
SAXN8R
Default Re: Instructions for changing Pads (chocoholic)
It is pretty self explainitory. Once you remove the wheels you will see the small bolts that hold the caliper to the caliper bracket. They are on a sliding pin that allows the caliper to "float". Just make sure you have new bolts or some locktite for when you re-assemble. If you just undo the top bolt you can swing the caliper down and remove the pads easily. Use the new bolt, or some locktite on the old bolt and re-torque to 23 lb-ft.
Oh, and one more thing.... I just want to tell you good luck, were all counting on you!
Old Jul 12, 2002 | 10:10 PM
chocoholic's Avatar
chocoholic
Default Re: Instructions for changing Pads (SAXN8R)
Great, thanks a bunch! You mentioned that the caliper is floating, do the pistons need pushing into the calipers before fitting the new pads? Finally, I don't have new bolts so it's time for our friend Mr Loctite!
Old Jul 12, 2002 | 10:26 PM
SAXN8R's Avatar
SAXN8R
...do the pistons need pushing into the calipers before fitting the new pads?
Yes, I forgot to mention that. It is recommended that you open the bleed screw and push the pistons back into the caliper with it open so you don't force fluid backwards through the system. If you do this, I would recommend that you bleed the entire system after replacing the pads. This will insure that you do not have any air trapped in the brake lines. Plus, it is a good idea to do a thorough flush of the brake fluid once a year or so.
Corey
Old Jul 12, 2002 | 10:51 PM
chocoholic's Avatar
chocoholic
Thank you again, kind sir!
Although I didn't mention it, I was planning on installing speedbleeders whilst I was doing the pads and then bleeding through with ATE. I haven't done 'vette brakes before but I assume I'm going to recognise the bleed valve when I see it in that it's going to be near a caliper and a brake line!
Old Jul 12, 2002 | 10:58 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
look for the little "rubber covered nipple".....I installed the speed bleeders when I did my rotors and pads a few weeks back :cheers:....3/8 wrench if I remember correctly :)
Old Jul 12, 2002 | 11:05 PM
SAXN8R's Avatar
SAXN8R
You are very welcome! :D
Old Jul 13, 2002 | 12:51 AM
TenaciousD's Avatar
TenaciousD
Speedbleeders - a fantastic invention! Whoever invented those needs knighting.
To Instructions for changing Pads
