Turn signals randomly quit!
Old Feb 5, 2014 | 12:03 PM
zach's silver1997's Avatar
zach's silver1997
Default Turn signals randomly quit!
I've got a 97 coupe that I recently purchased and the turn signals change from blinking very fast to slower than normal and now sometimes they just don't work and I have to press the hazard light button and turn it back off to make them work again! Any suggestions on what it could be or what to do?
Old Feb 5, 2014 | 12:49 PM
oh1vette's Avatar
oh1vette
More than likely the hazard switch is going bad - the signals run through it....
Old Feb 5, 2014 | 01:27 PM
chaase's Avatar
chaase
St. Jude Donor '12
It has been covered a number of times on the forum.
Old Feb 5, 2014 | 02:29 PM
zach's silver1997
How much does a hazard switch normally cost?
Old Feb 5, 2014 | 02:41 PM
Corvette_Ed's Avatar
Corvette_Ed
Old Feb 5, 2014 | 06:00 PM
oh1vette's Avatar
oh1vette
If I recall, I had mine done when I just got the car, went bad like 2 weeks after...think it was $250 installed at the dealer, but plenty of writeups on here to DIY...
Amazon.com: Corvette C5 Traffic Hazard Warning Switch: Automotive Amazon.com: Corvette C5 Traffic Hazard Warning Switch: Automotive
Theres also a bypass you can do:
http://forums.corvetteforum.com/c5-t...-shortcut.html
Or replace as original:
http://www.kd5fx.com/HSwitch/HSwitch.htm
Good Luck!
Old Feb 6, 2014 | 08:24 AM
dadaroo's Avatar
dadaroo
The turn signal flasher is in the Hazard switch. It also flashes for the hazards. Here is the wiring for it. You can get a new Hazard switch for about $25 and install it yourself. Your other option is to get one of the "hyperflash" units that are easier to install than replacing the Hazard switch. I also included my link on relocating the Hazard switch so it only takes about 30 seconds to replace in the future. Dash still looks stock. If you want to discuss the best way to remove the Hazard switch you can PM me with your phone number. It is not that difficult.
http://forums.corvetteforum.com/c5-t...elocation.html
Old Feb 6, 2014 | 12:44 PM
tacman's Avatar
tacman
St. Jude Donor '13
Hazard switch. Easy to replace with technique outlined in this Forum:
http://forums.corvetteforum.com/c5-t...placement.html
Cost about $20 or so.
Old Feb 7, 2014 | 01:03 AM
zach's silver1997
I don't really want to relocate it right now but I'll definitely be fixing this one myself! I don't plan on spending $250 when I can spend $25. Thanks for all the quick replies!
Old Feb 8, 2014 | 07:54 PM
Sids04's Avatar
Sids04
Do the bypass.. It's so easy...
Old Feb 8, 2014 | 08:10 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
You can also rap the dash right above the flasher with a tight fist until the signals work again. Been doing that for years.
No guarantee that a new flasher will fix the problem for long. C5 quirk. Never forget, Vettes are Chevys.
Old Feb 9, 2014 | 12:45 PM
2MFFZo6's Avatar
2MFFZo6
Just pop a new switch in there and will last a good 15 years or so..lol.
Old Feb 9, 2014 | 01:06 PM
dfp215's Avatar
dfp215
Did the by pass on mine two years ago. No problems. Easy step by step with pictures. Took all of about 1/2 hour to complete and a $5.00 flasher.. Great advise from this forum..
To Turn signals randomly quit!
