headlight adjustment ? Not the normal question....
Old Jul 14, 2002 | 05:04 AM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default headlight adjustment ? Not the normal question....
Is there a stop to adjust the amount of slop in the whole flip-up mechinism ? :confused:
Old Jul 14, 2002 | 05:12 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: headlight adjustment ? Not the normal question.... (MRWHOOPPEE)
TTT :flag
Old Jul 14, 2002 | 07:08 PM
Z11409's Avatar
Z11409
Motor assembly can be adjusted for lift and closing.If your headlight doors rattle in the down position,the small nylon lifting arm bumpers are worn thru-just slip off and turn them over so they wear on the other side or wrap in duct tape
Old Jul 14, 2002 | 10:14 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: headlight adjustment ? Not the normal question.... (Z11409)
mine rattles when up.Is it the same fix ?
Old Jul 15, 2002 | 01:14 AM
Z11409's Avatar
Z11409
Remove the black plastic headlight shroud around headlight after hand cranking doors up using **** on motor.Need flashlight to see ip lifting arm is up against white nylon bumper stop
Old Jul 15, 2002 | 02:51 AM
MRWHOOPPEE's Avatar
MRWHOOPPEE
thanks ! :cheers:
To headlight adjustment ? Not the normal question....
