water pump
Old Mar 8, 2014 | 02:41 PM
1981vette81's Avatar
1981vette81
Default water pump
hello, 1997 found was damp spot under car. Popped hood and felt under water pump and is all wet. So I assume the pump took a dump? Not a lot of experience on the ls series. so any suggestions welcome. Thanks!
Old Mar 8, 2014 | 03:18 PM
chris308's Avatar
chris308
easiest water pump to change on any car i ever owned! it's the gaskets that went bad on my car...
I used the "how to" on changing a cam for ls1's on ls1howto.com.
Once you drain the coolant and remove the belt, it's 6 bolts that hold the pump on.
http://forums.corvetteforum.com/c5-p...0-shipped.html
I believe was the best deal at the time when i was looking for a pump.
