Headlights
Old Mar 13, 2014 | 09:41 PM
bj454ss's Avatar
bj454ss
Default Headlights
My headlights are giving me fits. I have changed the gears, checked the grounds, and changed the relay but I still have problems. When I turn them on the lights they light up but they do not pop up. If I manually turn the motors just a little bit then turn on the lights they light up and pop up. They will work good for a few minutes then go back to acting up. It is like the motors are tightening up too much when closing and when turned on not enough power to turn the gears. Any suggestions? Should I grease the gears to help with the gear lock up it's experiencing?
Old Mar 13, 2014 | 09:53 PM
BobS98's Avatar
BobS98
Have you changed the motors? Could they have a dead spot in the armateur? I would be the first to admit that simulataneous (sp?) failure is unlikely?
Bob
Old Mar 14, 2014 | 10:30 PM
corvette77's Avatar
corvette77
Have you tried replacing the bumpers they rest on?
Old Apr 8, 2014 | 08:45 PM
bj454ss's Avatar
bj454ss
corvette77 thanks for the advice. I ordered the replacement bumpers from Ecklers. When I removed the old ones they were all chewed up. After replacing the old ones the headlights work like a Charm! Thank You very much!!!!!!
Old Apr 8, 2014 | 10:34 PM
corvette77's Avatar
corvette77
Glad it worked for you!
To Headlights
