Balancer bolt backed out ?
Old Mar 18, 2014 | 02:26 PM
123sugey's Avatar
123sugey
Dig
Default Balancer bolt backed out ?
My wife's C5 is sitting in a parking lot. The belts are off and the balancer is rubbing right against the stearing rack. What would be the causes?
Old Mar 18, 2014 | 03:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I doubt that the bolt backed out but, it is possible. A more probabale cause is the OUTER RING on the dampener seperated from the hub and slid forward and the outer ring is just contacting the rack.
The hub and the outer ring are attached together with a elastic rubber compound. Time/heat/vibrations eventually cause the rubber to lose its ability to bond the ring to the hub and you get what you have.
You may be able to pry the ring back to the center BUT, it will most likely come off again OR if it rides rearward and contacts the front cover, it will destroy it in short order.
Best to have it flat bedded to where ever you plan on replacing the dampener.
Its an involved job but something a seasoned wrencher can undertake.
Bill
Old Mar 18, 2014 | 03:13 PM
GoatKart's Avatar
GoatKart
Was just about to say, I've never seen a balancer bolt that was correctly torqued back out. Those things are torqued so hard, they are almost impossible to get out when you WANT to... GM didn't screw around with that bolt... lol
Old Mar 18, 2014 | 03:20 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Seeing how your car is stranded, Call me.. PM Sent.
Bill
Old Mar 18, 2014 | 03:40 PM
123sugey's Avatar
123sugey
Dig
Thanks guys for the help. I just got a trailer to pick it up. Will take everything apart this weekend
Old Mar 18, 2014 | 04:30 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by GoatKart
....... Those things are torqued so hard, they are almost impossible to get out when you WANT to... GM didn't screw around with that bolt... lol
But they damned sure did on the balancer vendor they used, especially on the earlier years '97-'99 ~. I've lost track on how many bad harmonic balancer threads I've seen here over the years.
Old Mar 18, 2014 | 05:02 PM
Blow Torch's Avatar
Blow Torch
That's the key
If the balancer has never been off, it proably didn't back out. If it has and was not installed properly, the bolt WILL back out (and throw the belts and hit the rack. )
Old Mar 18, 2014 | 08:34 PM
Paul 75 L82's Avatar
Paul 75 L82
It hard to get that bolt torqued to spec.
Old Mar 18, 2014 | 08:58 PM
LoneStarFRC
Originally Posted by Blow Torch
That's the key
The bolt is moot if the HB itself is self-destructing.
Old Mar 20, 2014 | 02:32 PM
Gordy M's Avatar
Gordy M
Several years ago, I had my bolt back out, but that was after several years of HPDE/time trials on Hoosiers. One track in particular had about a one mile stretch where you were between 5000 rpm and redline in third gear. The result of too much stress on the bolt.
What ever you do, pin the new Balancer and that will keep it in place.
Old Mar 20, 2014 | 05:34 PM
COSPEED's Avatar
COSPEED
St. Jude Donor '10
If you need a good replacement balancer and bolt (and even a pinning kit) we sell every balancer they make pretty much by any manuf.
Let us know if we can be of help!
Old Mar 20, 2014 | 09:35 PM
Chicago1's Avatar
Chicago1
Anyone break the hb bolt off? I have done 3 of them and that 240 ftlbs always worries me when I get to that point.
Old Mar 20, 2014 | 09:39 PM
COSPEED's Avatar
COSPEED
St. Jude Donor '10
I always like to use the ARP then I have no worries.
Old Mar 21, 2014 | 01:10 PM
Gordy M's Avatar
Gordy M
When I got to the 250 ft.lb mark on the torque wrench I found I was still 20+ deg. short of the 140. Got a 3 ft breaker extension and slowly worked the the last 20+deg. On the next one I did I found a 30 to 1 tool used for large trucks and did it one handed with no effort. However, every time I have had to lock the flywheel to keep it from turning. If you dont have a method to do that often 6th gear will hold it from turning.
Old Mar 21, 2014 | 09:16 PM
COSPEED's Avatar
COSPEED
St. Jude Donor '10
4th gear and parking brake works better.
Old Mar 23, 2014 | 09:21 AM
123sugey's Avatar
123sugey
Dig
Installed a stock one yesterday. Took 2 hours with a friend from start to finish with 2 jack stands. Hardest part was removing the bolt. Had to heat up the bolt a little and it loosened right up. The stearing rack was a little pain taking it out the drivers side wheel opening. My wife is happy so I am too
To Balancer bolt backed out ?
