Under engine hood lamp timer
Old Mar 27, 2014 | 08:29 PM
MAC5's Avatar
MAC5
Originally Posted by Bill Curlee
I was thinking the same thing.
The BCM looks for current draw to turn the lights back on. When you cycled the mirror light switch, the BCM turned the lights back on. Any electrical disturbance will start the timer over again.
Give it another try and see if the under hood light does go out after 10-15 minutes. Mine turns off after 12 minutes but some C5s do it sooner, some take longer.
Another thought. If something in the car is turning on and off (like your seat motors or lumbar pump motor), the timer will never turn the lights off.
Bill
Bill
When I installed a LED underhood light it would not shut off with the timer. In fact when the timer circuit kicked in, it actually went about 1/4 dimmer but not completely out. If I opened the car door it went back on 100% bright. I eventually soldered a very small miniature light in line with the LED into the circuit in the underhood light assembly. It has worked fine with that small additional load in the circuit. I'm thinking Clancy209 might have a LED in that housing. Just a hunch, it could be something completely different.
Old Mar 27, 2014 | 09:50 PM
bjones7131's Avatar
bjones7131
My 2001 times out, i thought it was messed up until i noticed it did it consistantly.
Old Mar 28, 2014 | 06:21 PM
Clancy209's Avatar
Clancy209
Bill
Bill
I was reading the reply from above. I have an LED light installed for more light. Sometimes when every thing shuts off he LED gets dim. Somehow the LED must be affecting the way it should work
Old Mar 28, 2014 | 06:23 PM
Clancy209's Avatar
Clancy209
Originally Posted by MAC5
Is there a regular bulb or a LED installed in that underhood lamp fixture?
LED installed do you think it has an effect.
Old Mar 28, 2014 | 07:45 PM
MAC5's Avatar
MAC5
Yes, see my note in post #21 above.
Note: I did this about a year ago and cannot remember whether I inserted that small bulb in series or parallel with the led. Maybe someone will chime in with a recommended resistor value that will work.
Old Mar 28, 2014 | 08:25 PM
Clancy209's Avatar
Clancy209
Thanks you might have solved my problem
Old Mar 28, 2014 | 09:05 PM
65GGvert's Avatar
65GGvert
That's the kind of information that could have helped get you a quick, correct answer.
Old Mar 28, 2014 | 10:12 PM
Clancy209's Avatar
Clancy209
Never entered my mind until MAC5 mentioned it.
