Flat rate hours
Old Mar 28, 2014 | 10:44 PM
NorthEnco's Avatar
NorthEnco
Default Flat rate hours
Does anyone know what the flat rate hours are for a C5 rear main seal
replacement ?
Bob
Old Mar 28, 2014 | 10:52 PM
TGO's Avatar
TGO
The book doesn't list hours for that job...it just says "bend over."
Old Mar 28, 2014 | 11:12 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Alldata 9.4 m6, 7.3 A4. Just make sure it's the rear main and not the oil pressure sensor leaking and running down!
Old Mar 29, 2014 | 09:30 AM
dadaroo's Avatar
dadaroo
Hopefully you know you have to remove the rear suspension and entire driveline to get to it. There are other things you want to inspect (or replace) once you are in there. This is a major effort, make the most of it.
Old Mar 29, 2014 | 12:56 PM
NorthEnco's Avatar
NorthEnco
Default what else
What else should I be looking for ?
Bob
Old Mar 29, 2014 | 02:17 PM
NorthEnco's Avatar
NorthEnco
Default been there
Definitely not the OP sender, been there done that
Old Mar 29, 2014 | 03:32 PM
lionelhutz's Avatar
lionelhutz
Make sure it's not the cam sensor first which could be fixed without pulling the drivetrain. With the drivetrain out make sure it's not the rear cover which can only be fixed with it out.
Old Mar 29, 2014 | 03:49 PM
NorthEnco's Avatar
NorthEnco
Default cam sensor
Could you refresh my memory. where is the cam sensor?
Old Mar 29, 2014 | 04:32 PM
StingrayRebel's Avatar
StingrayRebel
right next to the opsu
Old Mar 29, 2014 | 04:43 PM
NorthEnco's Avatar
NorthEnco
Default right
got to cut back on the beers
Old Mar 30, 2014 | 07:58 AM
dadaroo's Avatar
dadaroo
Bob
Manual or Auto? How many miles?
Old Mar 30, 2014 | 09:16 AM
helga203's Avatar
helga203
Old Mar 30, 2014 | 10:15 AM
NorthEnco's Avatar
NorthEnco
Default `C5 Auto
It's a c5 AUTO with 133,000 on the clock
Old Mar 30, 2014 | 10:47 AM
dadaroo's Avatar
dadaroo
Being an auto, I would put in a new pilot bearing and put in new torque tube couplings. There is also a bearing and seal (may be an o-ring) at the engine end of the drive shaft.
I have not been into one but this is from my parts manual.
To Flat rate hours
