Parasitic draw narrowed. Please help?
1997 corvette.
Stock. No additions!
Totalled before and I suspect the body shop messed it up on repair. Hes a jerk and refuses to help me; others (electricians) will charge me 1000+. Mechanics tell me they're not interested since it was totalled. When I was wrecked, a wire cut through the right hood up until 2 feet before the battery. It just messed up the front right but didn't touch the computer under the battery. So I have to figure it out.
About a year ago, the battery started running dead. It became more frequent until now it runs dead in 3 hours in the bitter cold; 20 h in the warm weather. No, I don't have a garage. Moving on. I had all the tests done that regular mechanics could do. The alternator was tested, I bought a new battery, and had checked all things like hood light, mirror lights, trunk light, brake lights, every light! I had to learn all about alternators; I didn't even know the name before. I'm learning
. I educated myself on parasitic draws and I tested it with a multimeter between the negative battery post and the negative lead. I tested it on amps, not milliamps, because that's the examples I watched online. Also, I'm afraid if I insert the red multimeter cable into the "V(ohm)mA" it'll hurt something. Anyway, I made sure of the following:1. Charged battery
2. Opened doors, pushed in door jam locks so the "door ajar" code was NOT there and all lights went off
3. Let it sit for about 1 h.
4. Then tested and pulled fuses from both fuse boxes (by battery and under passenger's side feet).
I found four fuses that registered on the "10A" position on the multimeter. The following fuses drew the following:
#37 -- 0.1 amps
#27 -- 0.01 amps
#25 -- 0.2 amps
#4 -- 0.6 amps.
Total amps through multimeter was 0.89 so it pretty much adds up. I pulled fuse 37 and 4 and it seems to be working. But the issue isn't fixed.
It makes sense because the drivers electric power seat only works sometimes. And upon jumping it before, the seat would start adjusting every which way automatically. I don't care about fuse 4 or the seat bc it's adjusted where I want it. Now for 37, it makes sense bc the under hood light does not work. As well, the mirror lights do not work.
Now when it comes to fuse 25 and 27, I have no idea, as it's currently way over my head. Especially 25 bcmi & ... I have no idea. Other things maybe related are when I pulled and then reinserted fuse 5, it's reset the multimeter to 1.5 Amps then drop down to the 0.8. When I pulled fuse 25, it dropped 0.2 amps; when I put it back in, it reset it the same as 5. The cigarette lighter fuse sparked, I looked at it, the metal twisted thing I dude was burnt, I replaced it with a spare fuse from under the hood, and then the cig lighter (that stopped working before) works again! I made sure to wait awhile before proceeding with the fuses. Could I drive it okay without all 4 fuses?
So what do I do next? I read similar on forums here but I got so lost. If you could tell me just one thing at a time and I'll do it then ask for the next thing that'd be awesome!
I need small instructions and simple words bc I'm not a mechanic. Thank you so much for your help!
If you remove the feed wire to the passengers foot well fuse box, you can see immediately if you have any abnormal current draws from the under hood fuse box.
If you connect the battery feed wire to the IPFB with a spare bolt and screw, you will see just what the IPFB is drawing.
NOTE! The BCM load sheds. When you first connect a load, the BCM comes out of sleep mode. Ive seen initial loads as high as 8 amps. Then it will drop down as the BCM shuts down things (i.e. interior lamps) I can take up to 12 minutes for the BCM to go into sleep mode. Sleep mode will be close to 20 milliamps.
Here are some common things that I have seen cause current draw issues over the past years:
Seat Control Modules
Seat control Multifunction Switch
Seat Lumbar Motor runs on and off
Head Light Control Module
Bose Amp
Rear Window Defroster
Interior lights always ON Dimmer turned full CW
Hood Lamp stays on.
BC
[/QUOTE]
Hi Bill,
Im so happy you responded! I've read a number of posts by you :-)
Could you help me? Here's the codes I got by pressing option and fuel 4 times. (Saw you said that in another post.)
10-PCM. P1571 H
28-TCS. C1226 H
38-RDT. NO COMM.
40-BCM. B0432 H
40-BCM. B0502 H
40-BCM. B0503 H
40-BCM. B0507 H
40-BCM. B0508 H
40-BCM. B2482 HC
40-BCM. B2527 H
40- BCM. B2587 H
40-BCM. B2592 H
40-BCM. B2593 H
Then when I kept pushing option after the codes ran (after "no more codes") I got the following:
10-PCM 1 codes
28-tcs 1 codes
38-rdt
40-BCM 11 codes (but there's only 10 above! I triple checked and it says 11 here but only gives 10. Peculiar.)
GOHhpc NO CODES
80-radio no codes
99-hvac
HO-ldcm 7 codes
Hc-scn
Bo-rfa 5 codes.
And those that I left blank were blank. I proofread above to make sure those were exact codes.
So many codes! Is there any hope for my poor car?
It is good to know what was in History so if it comes back you can watch it. Once you pull your codes and record them you can clear them and then see what comes back. It is normal for the system to throw codes that are temporary and don't come back. Just a glitch.
REMEMBER, pull your codes while the car is still running. If you pull them after you shut the car off then most codes will show as History.
Make sure that the battery is fully charged and clear the DTCs and then read them.
Bill
As the others have said, seat switch issues are common. Bill is a whiz with the car's electrical system so do what he says and he should be able to get you sorted out. A lot of screwed up cars have been helped by the forum. It helps to fill out your location information too someone may be in the area that can help you if needed.
Follow the guide lines provides Read the DTCs running or Ignition ON. What ever POPs up after you clear the DTCs,,,,, troubleshoot.
I read my DTC when ever the car farts wrong when Im driving. That includes driving down the road. Press Options/ FUEL and pull the DTCs... LOL Just dont reck!!!!!
Thats why GM says engine off ingition on.
BC
BC
You do that to RESET the OIL LIFE INDICATOR % in the DIC. When do you change your oil?? If you use the % oil life indicator, I dont know if its going to be correct.
You might want to check on that. When you change the oil, you "Turn the ignition switch to ON Engine OFF and pressing the accelerator three times. The oil Life Indicator should go blank and then to 100%
YES,, reinstall all the fuses and monitor the DTCs.
Bill
10-PCM. P1571 H
28-TCS. No codes
38-RTD. NO COMM
40-BCM. NO CODES
60-IPC. NO CODES
80-RADIO. U1016 H
99-HVAC. NO COMM
H0-LDCM. NO CODES
H1-RDCM. NO CODES
H6-SCM. NO COMM
B0-RFA. C2105 H
Bill
