Tires / Wheels Questions
Is there a good way to tell if the rims are true / straight or is it a crap shoot when buying used rims?
I'll probably go with Nito NT01, 275-40-17 on the front and 305-35-18 on the back. Any fitment issues with that combination wheels/rims on a 2000 w/Z51?
What are the best TPMS sensors I'll need for these wheels to work with the stock system. Do I need the original from 2000 or the newer ones better?
Thanks!
BTW: I frequently solder tabs to batteries. Gotta be fast, have a good solder station (better off with a high temp than lower), file the battery where you're going to solder, and use good flux. So far haven't had any explode.
