04 Base Coupe- Using the #1 Key Fob I unlock door, get in, insert key into ignition and the seat only moves up about an inch and then STOPS dead in in it's tracks yet if I push the #1 Memory button on the door the seat moves up to it's programmed position. At first I thought it might be the battery getting tired in the fob so I replaced it. Still doing what it's not programmed to do. I have had the car since Dec 2010 and it has only begun doing this with in the last couple of months.
Has anyone experienced this and if so what did you do to remedy the problem?
Hey Bill, Here’s what I got but I don’t know if it’s going to tell us anything as they are all H Codes: LDCM – B2282H- Battery #1 Fault,
B2284H- Battery #2 Fault.
RDCM – B2283H - Battery #1 Fault,
B2285H- Battery #2 Fault and B2287H- +5v Reference Fault.
There is no SCM codes at all.
I also had an IPC- B0516H- Speedometer Signal Circuit Malfunction. I wonder if I caused that code when I took apart the Gauge Cluster to replace the bulbs in the DIC? Anyway, like I said in my first post, I replaced the batteries in both Fobs. So I’m still stumped? I wonder if MAYBE there is a dead spot on the motor windings or maybe brushes need to be cleaned?
So I cleared all of the codes and I’ll keep an eye on it. If the seat travel acts up again I’ll check for any new codes.
Thanks for your help !
Not that it couldn't happen, but if that problem is what is going on with the OP's 2004 FOB's, that would be the first time I have read about it occurring on the 2001 and newer.......
Me too. It's not going to be a problem with the fob. The problem has been mentioned several times in the past. The seats (mirrors, steering wheel also) don't always go to the position set, even with the buttons. Sometimes you have to hit the button twice to get to the right position. The fob only selects which memory it SHOULD go to, if it opens the door, the fobs job is done and the battery is ok in the fob and the programming of the fob to the car is ok. The original OP's problem won't be with the fob, it will be with either the memory control in the car, or if it's only the seat that's an issue it could be with that module. One thing to try that may or may not help is to run the seat all the way forward and then hold the button for a few more seconds, then run the seat all the way to the rear and hold it for a few seconds. Then reset the memory position with the door button you want after unlocking the door with the fob you want it to match. After that it should go to the correct position with that fob. But many C5 owner's here can testify that it doesn't ALWAYS go to the correct position unless you press the memory button again. It should, but it doesn't.
"options not available" is the sure sign that neither FOB you have are programmed as #1 or #2. I went through the exact same thing a couple of weeks ago with mine. Do the long relearn process, which takes 30 minutes if done correctly. I did mine on the first attempt but I hear others havent been so lucky.
This video is what worked for me. Watch it entirely first, then try it out.
