Service Column Lock
Old May 8, 2020 | 09:54 AM
jrp1588's Avatar
jrp1588
Default Service Column Lock
Had the dreaded Column Lock error come up after an alignment. Thing is, I'm almost positive I don't even have a column lock anymore. With the car off, and front wheels in the air, I can steer side to side easily. With the error on, I was also still able to steer freely, but if I tried to move, the engine killed itself...for safety. Eventually after 8 or so tries, looking like a fool to onlookers, it was finally happy enough to get me home. I couldn't find much info on this specific failure mode, any thoughts?
Old May 8, 2020 | 10:40 AM
Dbl_D718's Avatar
Dbl_D718
Your car has had the recall performed which programmed in the 2 mph fuel cutoff. You're lucky to have gotten home; I was stranded 2 hours away when the same thing happened to me. I would recommend installing the LMC5 module which you can read all about on the forum. The LMC5 should resolve the error message and keep the car driveable, but the error can still pop up occasionally if the battery is weak. In my experience, if the error comes up with the LMC5 installed, the car is still driveable and the error can be cleared by disconnecting the battery for a few seconds.
Old May 8, 2020 | 11:07 AM
jrp1588's Avatar
jrp1588
I'll have to get under there and poke around to see what I have. I did a little more looking, and it sounds like if I have a bypass, it can become unsynced, requiring a reset by pulling some fuses. From what I gathered, on manual cars, the recall DIDN'T remove the lock, but I've never had a locking column even while the error was active.
Old May 8, 2020 | 11:59 AM
mmartinez's Avatar
mmartinez
Low voltage conditions sometimes trigger the service column lock message and cause the 2mph shutoff, sometimes the bypass's them self fail. Many c5 owners simply have a tuner change the 2mph fuel shutoff to 200mph, no more problems getting back home.
Old May 8, 2020 | 12:02 PM
jrp1588's Avatar
jrp1588
I could see that being the case. With the quarantine, the car has been sitting for the better part of 2 months, with only occasional starts to move it. Maybe the alignment shop left it on but not running too long, and it got low as well.
Old May 9, 2020 | 09:44 AM
bjones7131's Avatar
bjones7131
I installed the LMC5 on previous coupe and had MPH tuned to 200 MPH, guy charged me 100 bucks to do that with his TECH II eqp. I thought it was a little pricey. Now back in an a 03 Z06 and may role the dice until I get the error. Question: My car had the GM recall column lock fix done by previous owners and that is when GM did the 2 MPH thing to cover their butt if column should lock, I thought if the GM recall was done you would still have the theft capability with steering wheel locked, am I wrong on this. I know if LMC5 is installed you loose that and wheel will not lock. Thanks
Old May 9, 2020 | 09:59 AM
Gordy M's Avatar
Gordy M
More than likely you battery is going or you might have a bad alternator. Using a VOM and the engine off test the voltage of the battery. If it is below 12.5V that would lead to the problem. If so, disconnect the battery terminals, charge it and let it rest 24 hrs, and test again. If it is still below 12.5V you know it might not be the alternator but the battery. Or have it load tested to see the CCA capacity and RC capacity.
Old May 9, 2020 | 10:21 AM
mmartinez's Avatar
mmartinez
I would read the steering column lock FAQ sticky thread, it details what GM did for different year and manual and automatic cars.
jrp1588's Avatar
jrp1588
The battery would just figure. I had to replace both my wife's AND my beater truck's battery over the winter. Those things have gotten EXPENSIVE. I will say the car is still starting strong. Dash voltage (which I'm sure isn't terribly reliable) reads around 13v while running.
Old May 9, 2020 | 10:23 AM
jrp1588's Avatar
jrp1588
Yeah, I found it and read through. It sounds like my 2001 manual should still have the lock, but have the 2mph thing...which frankly I don't understand how that was supposed to fix the situation.
Old May 10, 2020 | 10:16 AM
mmartinez's Avatar
mmartinez
It didn't fix anything, it was GM trying to cover their butts in case the steering column locked up on the highway.
Old May 10, 2020 | 10:57 AM
jrp1588's Avatar
jrp1588
Nice. Sounds like they at least TRIED to fix the autos. Wonder why they took a different approach.
Old May 10, 2020 | 11:11 AM
jfslater98's Avatar
jfslater98
Possibly stupid question: if I can turn the steering wheel relatively freely, with the key not even in the ignition, has the CLB been implemented? I read the sticky mentioned above early in my ownership, did my test above and assumed all is well. Just re-read this, and the first couple Q+As seem to confirm my analysis, but maybe I'm missing something(?)
Q Can anything be done to unlock the steering column once it has locked up?
A Sometimes; turn the ignition OFF and REMOVE the key. Shock your lock motor actuator assembly by jerking the steering wheel against the stops.
I would think that if the steering column lock was still functioning, I couldn't move the wheel much at all.
Old May 11, 2020 | 08:07 AM
Gordy M's Avatar
Gordy M
In the early 2000's a GM engineering friend was at an autocross and his steering wheel locked on him. After calling several of his engineering friends friends he called me and I told him about jerking the wheel. Worked fine for him and he used it a few times that day.
Old May 11, 2020 | 11:16 AM
ersatz928's Avatar
ersatz928
It is possible that the installed CLB itself has failed.
Old May 11, 2020 | 11:27 AM
jrp1588's Avatar
jrp1588
Is it possible for it to be a fluke, especially if it was just a low voltage glitch? I drove it around the neighborhood a handful of times over the weekend, and had zero issues.
Old May 11, 2020 | 12:25 PM
mmartinez's Avatar
mmartinez
Possibly a fluke, there is no rhyme or reason why our cars suddenly have this kind of problems, my 97 goes for weeks and months with zero glitches and then suddenly I get the pull key wait 10 seconds message, and then it clears up without me doing anything to the car.
To Service Column Lock
