Hey I am doing this Saturday so I want opinions on why it would be bad or not work.
KThnx
Not sure if it would work I thought that the fronts and rears sent two different readings so that the computer could tell that there was the spec'd one inch tire diameter difference.
Yea if they all run to seperate sensor then it won't work, I just need to know what the yaw sensor needs to see to be happy and go from there then.
Yes I am blindly trying to fix it, but I have tried every thing else I can think.
Answer this question: At any time during your WOT run, do you ever need to turn the steering wheel off of dead nuts center to keep the car straight?
If the cars steering wheel is turned off center to keep the car straight, the EBTCM might think it needs to intervene to help keep the car straight.
When you thrust the car forward, the suspension bushings can compress and change the alignment enough to cause you to counter steer to keep the car straight.
I agree with Lionel,, The TECH 2 is the most accurate way to see what each sensor is reporting and why the EBTCM thinks it needs to intervene.
The yaw sensor tell the system how much it's turning. The SWPS tells the system how much the steering is turned. There are basically 2 reasons the system could be trying to correct itself. The yaw sensor says the car is rotating when the SWPS says the wheels are straight so the system tries to straighten the car out. Or, the SWPS says the wheels are turned but the yaw sensor says the car is not turning so the system tries to make the car turn.
I recall reading about a bracket or extra clip for the yaw sensor. Something to do with reinforcing the mounting location because otherwise the sensor can jiggle in the plastic and cause the AH system to act up.
What happens if you turn TC to COMP Mode or OFF?
Bill
I do also have QA1's so it weight transfers like a boss... This might do it though. Is there any way to beat my abs and Trac control system without the cars computer committing suicide?
