Stumped!!!! Please Help
Old Jun 4, 2014 | 12:54 PM
fsuforever's Avatar
fsuforever
0200 is injector code have u a volt meter? Check ohms to see if there all working don't just send it to a shop,it could be an easy fix ,get u a multimeter & check resistance using ohms ,start there,I would @least check resistance& wiring connectors before sending it off, that's just me, BTW, you tube is ur best friend on learning how to use meters
Old Jun 11, 2014 | 04:17 PM
1stZ06vette's Avatar
1stZ06vette
Well just to let everyone know I figured it out! The wire we used to splice in to the tach wire by the computer must of been bad. Disconnected that wire and hooked it back up the same way it was before all of that and now I have no codes any more!!!! God I hate wiring..... Thanks for all the help
