Stumped!!!! Please Help
Old May 26, 2014 | 08:42 PM
1stZ06vette's Avatar
1stZ06vette
Default Stumped!!!! Please Help
So a month and a half or so ago I installed a cam,intake,LS2 throttle body,fuel rails and bigger injectors,had the computer flashed and after wiring up the nitrous gauge,bottle heater ect.....now the car throws a P0118 and p0200 witch are a engine coolant temp sensor and a injector control circuit. I've checked fuses, some say it could also be the injector wiring rubbed threw the fuel rail and that's all fine. I changed the temp sensor and that's not it...... So idk this is frustrating bc I haven't really been able to drive the car and it's so nice out and I'm stuck driving my daily driver PLEASE HELP IF U CAN
Old May 27, 2014 | 02:38 PM
1stZ06vette
*BUMP There's got to be someone out there that can help me!!!
Old May 27, 2014 | 02:50 PM
Dcollins3208's Avatar
Dcollins3208
Have you checked your grounds?
Old May 27, 2014 | 03:27 PM
1stZ06vette
To the battery? Yes the other grounds no y should I ? I didn't mess with any of them
Old May 27, 2014 | 04:45 PM
D. Lil's Avatar
D. Lil
Is your temp guage reading on dash as well as the digital gauge? I had to coolant temp sensor code and ended up having a bad pigtail connector. Maybe that is the culprit?
Old May 27, 2014 | 04:47 PM
1stZ06vette
Yea the gauge on the dash at first reading 100 then shoots up to 260 if there is two temp sensors where is the second one at bc I only replaced the one on the drivers side?
Old May 27, 2014 | 06:09 PM
D. Lil's Avatar
D. Lil
I believe there is an engine oil temp sensor above the filter but after an install like you did I would suspect a broken coolant temp sensor which is located left cylinder head behind alternator. I broke mine after LT header install. Symptoms were a digital coolant temp readout of xxx and the analog gauge was pinged out.
Old May 27, 2014 | 06:11 PM
1stZ06vette
Yea that's what mine reads out on my info center but have replaced the sensor! How Likely is the plug n the prob JW
Old May 27, 2014 | 06:58 PM
D. Lil's Avatar
D. Lil
After I replaced the sensor twice I figured it must have been the wiring. While the car was running I moved the sensor wires around a bit and the car started studdering and died. Give that a try!
Old May 27, 2014 | 07:00 PM
1stZ06vette
Yea I'll try that and I'll let u know thanks
Old May 27, 2014 | 07:40 PM
Mike Beck's Avatar
Mike Beck
Unplug the sensor and see what the dash reading shows. Then take a paper clip or small piece of wire and short the connector, see what the dash shows. You are simulating the temperature extremes between full cold and full hot (around -40F and +260F).
Old May 27, 2014 | 07:42 PM
Mike Beck's Avatar
Mike Beck
By the way, if you own a DVM, you can measure the voltage at the connector (when it is unplugged from the sensor). You will read +5 volts between the two pins. It is current-limited internally inside the ECM so don't worry about shorting anything.
Old May 27, 2014 | 10:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Call me PM sent
Bill
Old May 27, 2014 | 10:36 PM
1stZ06vette
Ok will do right know and I'll get back to everyone and let u GUYZ know thanks again for all the help
Old May 27, 2014 | 10:51 PM
1stZ06vette
Ok well I unplugged the connector and the gauge went from cold 0-260 with the xxx on the gauge and then I tried the paper clip and it did the same thing!!!!
Old May 27, 2014 | 11:00 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Talk to Bill. He knows what he is doing.
Old May 27, 2014 | 11:16 PM
1stZ06vette
Yep just got off the phone with him
To Stumped!!!! Please Help
Old Jun 1, 2014 | 07:19 PM
1stZ06vette
Well just to keep everyone informed I think I'm to the end of patients so I think I'm going to have to take it n to a shop...... I think this will be the first time I've had todo that
Old Jun 2, 2014 | 10:01 PM
old stingray's Avatar
old stingray
Good luck.
Old Jun 3, 2014 | 11:20 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Did you check the PCM connector terminals? There have been corrosion problems caused by battery acid.
Did you follow Bill's recommendations? If you take it to the wrong shop or dealer, you could pay a lot to get it fixed, or not.
