Something wrong, sounds like a massive air leak.
Old Jun 14, 2014 | 01:43 PM
Jims2001's Avatar
Jims2001
Default Something wrong, sounds like a massive air leak.
Hi, haven't posted for a while just enjoying my C5 with no problems until today. Something sounds like a air leaking. Louder then something like a vacuum leak, not making a exhaust leak sound either. Louder under front of the car, started running a little odd also. Cruising town without having to press on the gas (auto) seams to idle too high sometimes not always. Isn't showing any codes, can't find anything out of the ordinary, bolts, belts, hoses. 27,000 miles. Any Ideas?
Old Jun 14, 2014 | 01:55 PM
Corvette_Ed's Avatar
Corvette_Ed
Did you check your vacuum lines just to make sure none were broken or cracked? Have you done anything new to the car recently?
Old Jun 14, 2014 | 02:15 PM
Jims2001's Avatar
Jims2001
Found it, the petcock on my oil catch can was loose. I only finger tighten that, somehow loosened up, must not had it tight enough. I guess that would make it run erratically.
Old Jun 14, 2014 | 02:16 PM
tommypenguin's Avatar
tommypenguin
Lumpy idle?
Old Jun 14, 2014 | 02:21 PM
Jims2001's Avatar
Jims2001
Originally Posted by tommypenguin
lumpy idle?
yep!
To Something wrong, sounds like a massive air leak.
