Hurst Shifter Rattle
Old Jul 25, 2002 | 03:02 PM
jimman's Avatar
jimman
Default Re: Hurst Shifter Rattle (RHILL)
Sure hope it's not worn, it's my new 02 with 800 miles on it
:confused:
Old Jul 26, 2002 | 03:27 AM
jimman's Avatar
jimman
Default Re: Hurst Shifter Rattle (jimman)
Ok back to square one, after all this still rattles and it's coming out.
Old Jul 27, 2002 | 12:34 AM
Snowman's Avatar
Snowman
CI 1-2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '03-'04-'05-'06-'07-'08-'09
Default Re: Hurst Shifter Rattle (Cyrus)
Cyrus, I did the stickon weight method to deal with rattle on Ripper shifter and it worked like a charm for me. I bent the wheel weights slightly so there was a curve for closer fit, used twist ties to keep them on. Everything is hidden under the boot. I have a Hurst on order. Sure hope I like it!
Doug
[Modified by Snowman, 10:35 PM 7/26/2002]
Old Jul 27, 2002 | 02:29 AM
jimman's Avatar
jimman
Default Re: Hurst Shifter Rattle (Snowman)
Snowman, I took 5 quarter oz weights and left them hooked together in a strip. Used 4 strips and black taped them to the shaft, great fit, still rattles like a bitch. Makes 50K car sound like s----. Some rattle some don't, it's got to be tolerances in the pivot assembly. I can't stand the noise so it's coming out and maybe I'll try another unit to see but right now it's not worth it.
Old Jul 27, 2002 | 11:21 AM
AFVETTE's Avatar
AFVETTE
I just tried adding Teflon Tape to the threads, and that didn't help. I remove the dam **** and all is well. What the hell does the **** have to do with all this noise. I may try the MGW solid billet ****. For $45 I can always use it as a paper weight at work.
Or I can drive the car sans **** and be noise free? This is GOOFY.
Tom
USAF Retired
Old Jul 27, 2002 | 11:30 AM
jimman's Avatar
jimman
Default Re: Hurst Shifter Rattle (AFVETTE)
Man I hear ya
