Drag pack fitment
Old Jul 8, 2014 | 09:43 PM
NukeC5's Avatar
NukeC5
Originally Posted by Capthuff
I'm going with 15x10 and 15x4 I'm not sure yet the back spacing on the rears, but I believe it's 2.5" BS on the fronts. I'm using the MT 275 Pro rears and MT ET Drag front tires. Remember, I'm a track only guy.
Exactly.. So wouldn't you want to be able to fit a larger drag tire back there? Assuming there is 1.25" of room to extend outward and inward, a 64 offset would allow for a 12" wide rim and extend the same distance inward and outward. I know there is room for that and probably with any tire too. I need to go measure the total distance from the fender to the inner areas. This will give an idea of the total width tire that can be achieved. Then I can chose a rim width that will fit that.
Old Jul 8, 2014 | 10:05 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
MT says the max recommended rim for the 275 Pro is 9.5"
I gonna talk to a few ultra and X275 guys and see what width they're using. I may go 11" or even 12"
Old Jul 8, 2014 | 10:42 PM
NukeC5's Avatar
NukeC5
Ya I guess Im just confused. 275/60 is not a very big tire at all.. I mean the ET streets I have now are 26x11.5 which translates to 295/60. And there's literally 2.5 to 3 inches of space around the tire. Especially towards the inner wheel well. I plan to go larger for sure. Im not totally sure yet, but Im thinking Ill be fitting a tire with a section width of around 13" maybe?? which will need a rim thats 11-12" wide?? I would assume..
Old Jul 8, 2014 | 11:30 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
I'm sure a 12" wheel and a 315 drag radial would fit nicely.
Old Jul 9, 2014 | 04:01 AM
RonSSNova's Avatar
RonSSNova
The MT 275/60 Pro is 28" tall which is hardly small.
It's also the best drag radial in existence.
Ron
Old Jul 9, 2014 | 10:02 AM
NukeC5's Avatar
NukeC5
Ron
This tire is a purpose built restriction for a specific class. It certainly is a good tire and Im sure it performs well. But there is better out there. Why limit himself if he doesn't have to? Here is what it says on MT's site:
http://www.mickeythompsontires.com/s...treetRadialPro
Besides.. the ET "Street" was always a DOT street legal tire. Now its not while retaining the name ET Street. Not very well thought out in that area..
And anyone with a lowered vehicle will have to raise it back up to accept the 28.2" diameter.
Now I dont know about the compound in this one, but here is just an example of a 26" tall tire with 12" of actual tread on the ground that fits a 10" rim. Im just saying. There are a lot of options out there.
http://www.mandhtires.com/M-H-Racema...5#.U71Kn_ldWCo
The taller the tire, the less effect the gears have. Ive heard its best to stay with a smaller diameter if possible.
Old Jul 11, 2014 | 07:54 PM
NukeC5's Avatar
NukeC5
Alrighty, Ive done a bit more research and found whats out there and the options. Its surprising how few sizes of tires there are to choose from in a certain diameter etc. for a given width rim. I realize now that a 10" rim accepts a pretty big tire when it comes to drag slicks, unlike street tires.
Here is my current choice for my next drag pack:
Wheels: Weld Alumastar 2.0 size 15"x10' rear and 15"x3.5" Front. http://weldracing.com/alumastar-series.html#6
Tires: MT ET Drag 26"x11.6" rear. http://www.summitracing.com/parts/mtt-3053
And Im thinking the 25x4.5 MT ET front runners. http://www.summitracing.com/parts/mtt-3001
Should be fine with 1" difference between the front and rear if I remember correctly?? Something about the TC system. Not that Id be using it anyway. There is a 24"x4.5" option in this front runner too.
Now heres where I have questions. I am trying to consider the correct backspace. I can choose either 7 or 8 inches for the rear rim. The stock wheels are 18x9.5 with a 7.5" backspace. So if Im doing the 10" wide and used the 7" back space, that would in effect push the tire outwards while deepening the dish?? And the 8" a little inwards (tucking the tires under towards the body)?? Am I on the right track, or do I have it backwards?
Old Jul 11, 2014 | 11:36 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
The 24" front is really short and looks funny. I would probably use the 25". Currently I have the 26", but next time I buy fronts, I'm going with 25". It'll help a little with R/T.
You are correct in your assessment of the back spacing. If you have flared rear quarters, get the 7" BS. I would think they'd stick out too far with stock quarters. I'm getting the RT-S at 15x10 and 7.5" BS.
Good luck. The 2.0 is a really cool looking wheel.
Old Jul 12, 2014 | 12:07 AM
NukeC5's Avatar
NukeC5
Ya, I think the 25" is where it's at. I've debated tubbing or flaring in the back, but just going to fit these for now. At my power level I really dont need more. I think I will be fine with the 7" back space because my current ccw rear is right at 7.5" back space. This is basically the exact same size as I am currently running and I think I have plenty room for 1/2" more outboard.
But then again, if I do the 8" it will allow for future growth in tire size without flaring the fenders. I just would like to have a little more of a deep dish look. They look a lot better that way. But of course, practicality is more important than looks..
