Corsa x pipe install question
Old Jul 24, 2002 | 04:00 PM
PaceThis's Avatar
PaceThis
Default Corsa x pipe install question
Dealer just called, said the x pipe needed flared to get it correctly fitting over the cats...whose done this??? Do they need to do this/?
Old Jul 24, 2002 | 06:35 PM
Mr. C's 5's Avatar
Mr. C's 5
Default Re: Corsa x pipe install question (PaceThis)
No. The H pipe section is to be cut off, using precise measurements, with a chain pipe cutter. Then the x pipe section slips over the pipes coming from the cats is clamped using the provided hardware. Take a look at the instruction sheet. – C.
Old Jul 25, 2002 | 04:35 AM
hdrider's Avatar
hdrider
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
When I installed the Corsa X-pipe I had to grind down the existing exhaust pipe where I cut it with chain cutters to smooth the burrs around the cut. I ALSO had to use an exhaust pipe expander to slightly expand the Corsa X-pipe before I could slip it over the cut pipe. By "flaring" I'm assuming that the dealer just meant that he had to expand the opening slightly to gtet it to fit -- but why would the dealer call you about something that trivial??
I did the work myself (without assistance) in my garage with the rear end of my vette on a car jack -- I took a day because I didn't have any help, it was crampede quarters underneath, and I had to go out and buy the exhaust pipe expander. When I got done it was worth it.
Dennis
Old Jul 25, 2002 | 09:16 AM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
???? Here is a how-to from my X-Pipe install Click Here
To Corsa x pipe install question
