Ignition key problem?
Old Jul 27, 2014 | 12:08 PM
Dave-A's Avatar
Dave-A
St. Jude Donor '14
Default Ignition key problem?
When I remove the key from the ignition it should unlock the doors, etc.
Occasionally it does not do this unless I reinsert the key and then pull it out again.
I am assuming something has worn and will only get worst with time. I would like this to work more consistently.
While I could have a new key cut I am wondering if this will solve my problem. Seems if I have a key cut off of a worn key I will now have two worn keys and the same problem!
Is there a way to look up a key cut code number and have a new key cut based on the key cut code number.
I could probably solve my problem by getting in the habit of pushing the key in before removing it, but this is difficult to remember to do!
Old Jul 27, 2014 | 01:07 PM
Chicago1's Avatar
Chicago1
https://www.corvetteforum.com/techti...=153&TopicID=2
1 392
2 523
3 681
4 887
5 1.13k
6 1.47k
7 1.87k
8 2.37k
9 3.01k
10 3.74k
11 4.75k
12 6.04k
13 7.50k
14 9.53k
15 11.80k
http://forums.corvetteforum.com/c5-t...ch-repair.html
Old Jul 27, 2014 | 01:39 PM
Dave-A's Avatar
Dave-A
St. Jude Donor '14
Battery is new, top of the line die-hard (30-60 days old). No codes.
I am wondering if it may be the piece that reads the code, how else would it know that the key has been pulled?
Old Jul 27, 2014 | 02:12 PM
65GGvert's Avatar
65GGvert
The code it reads only allows the car to start, it doesn't tell it to unlock the doors.
To Ignition key problem?
