Weird cruise control
Old Aug 10, 2014 | 06:28 AM
quick89's Avatar
quick89
Default Weird cruise control
Works perfectly with (M6) in 4th gear but get almost immediate dis-engage if trans is in 5th, clutch and brake switches ok
Old Aug 10, 2014 | 08:48 AM
dadaroo's Avatar
dadaroo
That's a new one. DIC codes should provide an insight.
If you don't know how here is something to look at:
Old Aug 10, 2014 | 12:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The cruise control function comes out of the TAC module. It doesn't care what gear you are in so, the fifth gear selection its self should have nothing to do with it.
Try this (Yes I know that you said the switches are fine) Pull up on the Brake peddle with your foot and try the fifth gear test. Then do the same for the clutch.
Next. Put it in fourth and engage cruise. While in cruise, press the accelerator (while still in cruise) and accelerate and then let off and see if it drops out.
When it drops out in fifth, without changing anything immediately read the PCM DTCs
Bill
Old Aug 11, 2014 | 06:22 AM
quick89's Avatar
quick89
Default weird cruise
1571h
Old Aug 11, 2014 | 09:30 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hmmmmmm.... DTC P1571 Traction Control Torque Request
Old Aug 12, 2014 | 07:24 AM
quick89's Avatar
quick89
Default weird cruise control
Tried raising both brake and clutch with no change also with traction control on and off. I have one button for TC, no active handling I think but coilovers are installed, think that makes a difference?
Old Aug 12, 2014 | 06:19 PM
dadaroo's Avatar
dadaroo
Please complete Bill's requests in the 3r sentence and report the result.
Old Aug 14, 2014 | 06:22 AM
quick89's Avatar
quick89
With car in 4th with cruise control on if I accelerate then let off will resume the set MPH. No PCM codes after reset after this trial of the cruise control. I noticed the clutch switch does not rachet out like the brake switches, do you have to screw that one out?
Old Aug 14, 2014 | 04:35 PM
dadaroo's Avatar
dadaroo
Thanks for the info. Will get you an answer on the clutch switch in the morning as I am not at home now.
Old Aug 15, 2014 | 06:52 AM
dadaroo's Avatar
dadaroo
There is no adjustment on the clutch switch, it is attached to a bracket that just bolts on. Remember it is the one at the top of the pedal and the start interlock switch is at the bottom.
Old Oct 2, 2015 | 10:53 AM
73Corvette's Avatar
73Corvette
SO, what happened? No more responses? Did you get it figured out?
Old Oct 2, 2015 | 01:06 PM
lionelhutz's Avatar
lionelhutz
The P1571 is normal if the car is a 97.
Old Oct 2, 2015 | 01:21 PM
73Corvette's Avatar
73Corvette
gotch ya... Thanks
To Weird cruise control
