ANOTHER PCV question
Old Aug 14, 2014 | 11:50 AM
scott1974's Avatar
scott1974
Default ANOTHER PCV question
Will someone please tell me which way vapors and vacuum are flowing in this diagram? In all the hoses? I'm setting up PCV just like this on a 408 but I'm trying to understand where the "fresh" air is coming from, if at all. I'm also trying to understand which direction the PCV valve needs to be oriented.
Thanks in advance!
Old Aug 14, 2014 | 11:57 AM
scott1974's Avatar
scott1974
It seems like the hose going from the passenger side valve cover to the bellows before the throttle body (LS2 TB) would be under vacuum from the venturi effect of the air rushing into the throttle body. Also the port on the intake manifold is vacuum so it seems they would be working against each other.
Maybe some simple directional arrows would help me understand better.
Sorry if this is a dumb question...
Old Aug 14, 2014 | 12:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is the LS1 & LS6 PCV actual hose routing schematic's:
LS6 Vacuum from the intake manifold pulls gasses from the block into the intake for disposal via compustion:
LS1
The manifold connection pulls gasses from the rear of the valve covers and into the intake for disposal via compustion:
ON BOTH systems, there is a fitting on the same side of the Throttle body that allows metered fresh filtered air into the block to replace the air/gasses that the PCV system removes. You can see it very clearly on the LS6 PCV picture.
On both systems, it connects to the front fitting on the passengers side valve cover:
Follow the connection line carefully as its difficult to distinguish it. (showing LS-1 system.)
This is the port inside the TB where the fresh air for the block comes from:
When you add an after market FAST 90mm & 90 mm TB to a C5, the 90 mm TB does NOt have the fresh air port. So, you have to find a way to get Metered Fresh Air into the block. That is where I temproarily tapped into. I have since replaced the coupler and took the air from the other side of the air bridge on the flat spot. i installed a brass 90 deg barbed fitting and routed the hose under the TB back to the passengers valve cover.
Bill
Old Aug 14, 2014 | 01:01 PM
scott1974's Avatar
scott1974
That clears it up for me! Thanks Bill!
So I'm guessing when the throttle blade is open far enough, the vacuum of the air rushing into the manifold would overcome the vacuum created in the crankcase (valve cover port) making the PCV system inoperable until the crankcase vacuum is greater than the venturi effect of the hose plumbed in the red coupler? Following me? Is PCV only happening at low rpm?
As an experiment I think I will attach my vacuum gauge to the hole in the red coupler and see what kind of venturi effect vacuum is there under different rpms. Maybe its much less than I am imagining. Then I will do the same with the port on the valve cover. Will be interesting to see...
Thanks again Bill!
Old Aug 18, 2014 | 08:36 PM
scott1974's Avatar
scott1974
To ANOTHER PCV question
