Broken Starter Bolt
Old Aug 31, 2014 | 03:41 PM
  #41
john8642's Avatar
john8642
Originally Posted by robert19890412
The bolts on the upper part of the engine seem to be fine, Last year the water pump was replaced and I reused the bolts (big mistake because it is leaking now) I ordered new stainless ones and will feel safer torquing those.
The exhaust system, you don't need to take the entire H out all you need to do is undo the 6 bolts at the flanges and the 4 bolts on the the 2 supports, so you wont need to buy new gaskets for where the cat back section is.
3 weeks ago I pulled the H to fix an exhaust leak and I broke 4 of the 6 flange bolts. So I ended up needing to pull the exhaust manifolds which is very easy to do just slightly time consuming. The bolts all came out of the head with no problem and those are on the side. I only assume the ones on the top of the engine are fine.
Just remember even with stainless bolts, you're torqueing them into an aluminum block. You also should invest in a can of Kroil. It's an industrial strength penetrating oil. I used to work construction in power plants, and the millwrights used it when disassembling the gas turbines. That should save you from breaking so many bolts.
Amazon Amazon
Old Aug 31, 2014 | 07:05 PM
  #42
robert1989's Avatar
robert1989
Originally Posted by lionelhutz
I wouldn't trust that fix myself. Your starter alignment won't be worth a crap. The knurled part of the bolt aligns between the starter and the block to keep it straight in line. All those washers are killing that alignment.
I broke about 3 or 4 of the flange studs so I took them all out without removing the manifolds. It was actually really easy to get them out.
I purchased the car 5 years ago from a dealer in NC apparently way to close to jacksonville.
Any ways, The flange bolts must of been busted before because it never had studs. Not now it has 1 normal flange bolt 4 7/16 bolts and 1 big *** metric bolt. Seals nice at least. Through bolts are a much better option with these you need to be quite hand in getting a ratchet around one of them but after you figure it out it is no big deal.
I talked to a physicist I know and he said that I should have nothing to worry about when it comes to the starter torquing because all the torque is on the "good bolt" the other side is pretty much an alignment issue and holding it to the block. He also said it appears the original starter was designed backwards and that the small tab should of been on the opposite side. (also he added he wasn't a mechanic so he could be wrong).
Old Sep 1, 2014 | 02:43 AM
  #43
SG Lou's Avatar
SG Lou
Kroil is great stuff. I work in a Power Plant and that's all we use here !
Old Sep 1, 2014 | 09:15 PM
  #44
phoenix1017's Avatar
phoenix1017
I don't know if this is an option for you but my starter broke off along with a piece of the block (split the bolt hole in half that the bolt goes through) when my Vette hydro locked, Luckily I still had the peice that broke off. I welded it back with JB WELD! That was 2yrs ago and its still holding. Something to consider if you have that option. Whatever you decide, good luck.
Old Sep 1, 2014 | 09:19 PM
  #45
bjones7131's Avatar
bjones7131
What is jb weld?
Old Sep 1, 2014 | 10:56 PM
  #46
SG Lou's Avatar
SG Lou
Originally Posted by bjones7131
What is jb weld?
A 2 part steel reinforced epoxy !
http://www.jbweld.com/product/j-b-weld/
Old Sep 1, 2014 | 11:27 PM
  #47
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Mind broke when I had a coolant leak hydro lock in #1 Cyl.
I went the TIG welding route and my welder reinforced the damaged area. The add in that starter bridge link stated that welding wouldn't last long. Bahhhhhhhhh Haaaaaaaaaaa. I used the talents of a Nuclear Welder and let me tell ya.. Its better than NEW!
Good as new!
We did such a good job at matching the break, clamping it back, spot tig welding, V grooving the crack between the spot welds and then reinforcement welds that I was able to use the original threads in the damaged hole without issue.
I was ready to use a TINESERT but I didn't need to.
Bill
Old Sep 2, 2014 | 12:03 PM
  #48
IRON MAIDEN's Avatar
IRON MAIDEN
Good as new!
Bill
This is the proper fix. If the ear is already broken off.
Yours isn't yet. Like mentioned several times before, why are you not considering a nut and bolt? Make sure the hole is drilled straight. Get a grade 8 shoulder bolt with the shoulder long enough to reach into the block ear, then torque it down. The shoulder will work like an alignment pin and keep the starter from moving. Sure seems like an easy fix being yours isn't broken off yet. Use an oversized washer on the back side to support the ear to help it from breaking off down the road. If it ends up snapping off, do what Bill did.
Old Sep 2, 2014 | 02:58 PM
  #49
SG Lou's Avatar
SG Lou
"Oh Well, wherever, wherever you are,
Iron Maiden's gonna get you, no matter how far.
See the blood flow watching it shed up above my head.
Iron Maiden wants you for dead."
Sorry, couldn't resist !
