What causes the "REMOVE KEY FOR 10 SECONDS"?
Old Aug 30, 2014 | 04:41 AM
scottsphoto2's Avatar
scottsphoto2
Default What causes the "REMOVE KEY FOR 10 SECONDS"?
warning to come up on the steering-wheel display sometimes?
The engine turned off while in reverse one time, then I seen this, and after doing it, cranked and ran fine.
Anyway, it just started doing this, (about 5 times in the last 3 mths)just wondering if its anything to worry about?
1997 c5
Old Aug 30, 2014 | 07:46 AM
65GGvert's Avatar
65GGvert
Instead of typing out all the possibilities again, I'll tell you how to read about it. Go to Google, type in the search box "c5 corvette remove key wait 10 seconds". You can read about the cause and fixes and it will help you understand how the column lock works and how you can fix the issue very inexpensively.
8vette7 is an excellent resource here for particular year and transmission type help. Either type here or PM him your transmission type (auto or manual) for your 97 and you'll be on your way.
Old Aug 30, 2014 | 09:16 AM
rws.1's Avatar
rws.1
leading prospect a dirty resistor pellet on the key. Wipe the key with an alcohol swab .....
Old Aug 30, 2014 | 02:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by 8VETTE7
See response in BLUE above.
100% On the mark! Follow these recommendations. Im my PM that I sent you, I also warned you aboout the battery and battery health and the column lock bypass.
BC
To What causes the "REMOVE KEY FOR 10 SECONDS"?
