I have a c5 . My volt meter has always read a steady 13.8 . It just started jumping up to 14.1 down to 12.6 back to 13.2 13 .8 in other words all over. The car has 90000miles. Does it need new gen.
This has been stated many times. The DIC digital voltage reading and the IPC analog volt meter DOES NOT represent actual battery voltage.
It shows the voltage coming out of the IGNITION SWITCH.
If your DIC and Analog meters are not stable, I would suspect the Ignition Switch or that complete circuit.
Obtain a hand held DC voltmeter and read the actual battery voltage on the battery terminals. Compare that voltage to the IPC meters.
IF,,,,,,,,,,,,, That voltage is jumping around on the battery terminals, check the connections on the Starter Solenoid. The Charging Path from the alternator to the battery is: From the BATT terminal on the back of the alternator down to the solenoid main terminal and up to the battery POS terminal.
Those are the steps that I would take before replacing parts.
I've seen that starter connection Bill told you about cause what you're seeing on three C5's. On one, the owner didn't do anything and it eventually didn't start. By the time he checked the connection, the bakelite around the post in the starter connection was charcoaled and the starter had to be replaced. (he could have probably replaced the solenoid, but the starter had to come out anyway so he replaced the starter)
