Rear end grinding on tight turns
Anyone have any experience with this or can otherwise comment ? Thanks
If you change out the lube and it still makes noise on tight turns, you may need to add some additional limited slip additive.
The additive allows the limited slip clutches in the differential to slip. DO NOT add too much.
IF,, that spring breaks, the clutches no longer have the correct preload and fail to function as a limited slip unit. YES, they can cause noise and abnormal wear.
Have the garage jack up ONE rear wheel, the other rear wheel still on the ground and put the Trans in Neutral. Try to rotate the wheel that is off the ground.
If the clutches are operating correctly, it will be very difficult to rotate that wheel (cause the clutches to slip) New clutches have over 100 ft/lbs break away torque
If the springs are broken, it will be pretty easy to rotate that wheel.
Then check the opposite wheel the same way!
While the wheel is off the ground, grab the wheel at the 12-6 O clock and then 9-3 O clock positions and push and pull to see if you have any slop in the rear wheel bearings.
You should have very little or NO slop in either wheel bearing.
Here is a picture of a good and a broken Belleview spring (BAD on the RIGHT, GOOD spring on the LEFT!
Here a post that shows you the inside of the rearend and where the springs are:
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
Just use the GM stuff with the proper amount of LS additive in it; P/N is 88862624 or 10-4034. As others have said, too much LS is just as bad as too little. I've had great luck with this stuff, a little less than two quarts.
2 ounces of the ACDelco additive did the trick.
