radiator
Old Sep 28, 2014 | 06:26 PM
latenightlarry's Avatar
latenightlarry
Default radiator
recently bought a de witts from a forum member for my c5 z. as it turns out its for an automatic that has an trans. cooler built in. seams to me if i plug the ports for the trans cooler it would work the same a a manul trans. radiator. pluging the ports just to keep dust and grime out. any thoughts. thank for advise larry
Old Sep 28, 2014 | 06:27 PM
SG Lou's Avatar
SG Lou
Shouldn't hurt a thing...plug away
Old Sep 28, 2014 | 06:43 PM
American Heritage's Avatar
American Heritage
Supporting Vendor
You can use a auto trans radiator with a manual trans. Just plug up the trans cooler line holes so no debris gets in there (in case you ever want to use the trans cooler part). No worries at all.
Old Sep 28, 2014 | 07:01 PM
latenightlarry
speaking of that could the trans cooler be used for a manual trans
Old Sep 28, 2014 | 07:12 PM
SG Lou's Avatar
SG Lou
No...Auto trans has a pump to circulate the oil, manual does not.
Old Sep 29, 2014 | 09:21 AM
ScaryFast's Avatar
ScaryFast
There are kits to add the manual trans cooler if your car was not so-equipped.
Look at LG or DRM.
Although on a street-only car there's no reason to bother.
Old Sep 29, 2014 | 07:28 PM
White Out's Avatar
White Out
Could it be used as a secondary oil cooler?
Old Sep 30, 2014 | 09:44 AM
latenightlarry
good question, anyone?
Old Sep 30, 2014 | 02:30 PM
ScaryFast's Avatar
ScaryFast
Possibly. You would need to know the size of the cooler. It may be too thin and cause a restriction in the oil system. If it's basically the same as the standard EOC it would be no issue.
But again, why? If you have the standard EOC in the DeWitt you should not need a secondary one.
Old Oct 1, 2014 | 12:06 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just plug the holes and use the Rad.. Will be good to go!
To radiator
