exhaust help
Im sorry to say,,,, you will need the ZO6 manifolds. They are much different in the outlet location of the manifold.
That being said,, the ZO6 manifolds are worth a few more HP.
NOTE! You will nedd a ZO6 (2001+ ) oil dip stick and tube if you change out manifolds.
Bill
Bill
Use the standard GM gaskets. The bolts should come out easy and are reuseable.
The ONLY questionable area are the manifold to midpipe bolts. Some times they are frozen and snap.
Do you have the C5 ZO6 Ti Mufflers???????
Oh... The exhaust manifold to block bolts are torqued to 18 ft/lbs
Change your plugs and wires. I use the GM Performance RED wires. Cant beat the quality and price. The Stock GM Irridium plugs are also excellent. If you have heada and cam, there are other choices.
Dont forget,,,,,,,, You will need a NEW C5 late modle dip stick and tube!!!!!!
You will have to MODIFY the passengers side A.I.R. air tube to fit in a modified location. I cut the metal tube and used a piece of high temp silicone hose to reconnect.
Bill
Bill
Bill
Bill
Thanks,
Joe
That being said,,,,,,,, A mid pipe that will fit is a midpipe that will fit. If the CATs are good on the ZO6 midpipe,, it should fit what ever you have now. The shop SHOULD be able to fit your muffler setup (axel back system) to a stock midpipe.
Stock C5 midpipe (applies to ALL C5s) Note,, early midpipes DO NOT have PUP CATS, 2001 ZO6s had PUP CATS, 2002+ ZO6s did not. What is the year and MOD of your midpipe
The midpipe shown is a 2004 Coupe midpipe (with PUP CATS)
Bill
Bill
S
