Help! Problems with 99 frc.
Old Oct 26, 2014 | 03:40 PM
zackf33's Avatar
zackf33
Cruising
Default Help! Problems with 99 frc.
I'm looking to get some input on what may have happened to my Vette. I had it at the track for the first time last night. I went to take off from the line, and there was a loud pop when I took off. I put it in gear and when I let off the clutch there is a slight rattling/grinding, it will not move at all. I'm thinking it's something to do with the torque tube. It is a 99 FRC 6 speed making around 430rwhp. Any info would be great. I can provide any additional info on the car if needed. Thanks.
Old Oct 26, 2014 | 04:05 PM
chris308's Avatar
chris308
broken diff?
Old Oct 26, 2014 | 04:29 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Broken output shaft, most likely. Jack up the rear and see if you can spin one wheel freely,, If so, that out put shaft is busted.. If both wheels are still limited slip locked together, you broke the trans output shaft.
This guy just did the same thing"
https://www.corvetteforum.com/forums...ack-today.html
Here are some interesting post for you:
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
I running 450 RWHP and this works excellent for me.
BC
To Help! Problems with 99 frc.
