Fuel Gage on EMPTY
Old Nov 10, 2014 | 09:42 PM
Duhvet's Avatar
Duhvet
Default Fuel Gage on EMPTY
I have a 2002 C5. Today while driving and knowing that I had about 3/4tank of gas, the gage is showing Empty and Check Gages light came on. I have been using Chevron gas with Techron.
Any Idaes of what is going on?
I was told that I could reset it somehow.
Does anyone know of the code?
Old Nov 10, 2014 | 11:00 PM
Bluemill's Avatar
Bluemill
Default this happened to me a year ago....
What happened to you happened to me except I have a high mileage car, (at that time I was at about 92,000 miles or so,) and I had about 3/8th tank when all the warnings came across the DIC.
It was a Friday night, researched the hell out of it, and most info pointed to bad gas, likely with a high sulfur content. I went to the closest auto parts franchise and got the 20 oz. bottle of Techron fairly early before playing golf the next day. Poured it in prior to hitting the links. Came back after 18, and was going to put some Shell premium to finish off the fix- Turned on the car, the gas gauge came right back, and its been fine ever since.
I had bought too many tanks of cheap gas in a row, and it gummed up the sender in the tank.
Best always,
Bluemill
Old Nov 11, 2014 | 12:44 AM
foggy's Avatar
foggy
Use Techron with your next couple of fill ups.. Should do the trick
Old Nov 11, 2014 | 02:10 PM
jackthelad's Avatar
jackthelad
Per Joeflyer: The TSB for the fuel-gauge problem is 010604022. It's a computer update.
Had that done to mine maybe 9-10 years back. Has not re-ocurred since. Used to happen regularly, Techron or no Techron.
Also see: www.chevroletproblems.com/tsbs/Corvette/2000/
Look under fuel system, other.
Old Nov 11, 2014 | 03:38 PM
Russell Boulding's Avatar
Russell Boulding
02-06-04-010A is I believe the latest TSB on this issue. It covers the sulfur issue as well as recommending the PCM update. This fuel level system will default to zero when it cannot make sense of the data coming from the level sensor. This can happen either from sulfur coating of the sending unit or from chemical reactions caused by certain sulfur compounds inducing voltage on the sending unit. This issues should not be present with the use of top tier fuel, which you are already using. The PCM update desensitizes the strategy that causes the fuel level to read zero. I feel the PCM update is probably the best course of action based on the information given.
But, most of the fuel level issues are erratic and intermittent in nature. Is the fuel level still reading zero continuously? If so how far have you driven and have you added fuel since it happened?
Old Nov 11, 2014 | 10:58 PM
rodsvet's Avatar
rodsvet
It may be your jet siphon pump in the passenger tank. Try the techron for a few tanks and you may be lucky. If you have the first generation fuel system the jet pump is not too hard to clean. If you have the second generation system, then you have to drop the tank. Good luck, Rod
Old Nov 12, 2014 | 11:04 AM
fmvette9's Avatar
fmvette9
I have an 02 and had this happen once at the 3/4 fuel level also.
There is a cross over between the right and left tanks a little below the 3/4 level, which will keep the tanks equalized above the 3/4 level. Below this, and the jet siphon pump will keep the left side tank at a higher level than the right by design.
IF the PCM detects the right side tank higher than the left, it sets the fuel gage to empty.
When mine set, I had just driven through a series of S curves, and my theory is that the right side received fuel from centrifugal force through the cross over.
When the car sits, the two tanks will equalize through the jet siphon pump. If you fill completely up, the cross over will equalize them. Both actions should clear the alarm if the right side tank "somehow temporarily" (and the fuel sensors and jet siphon pump are not defective) got higher than the right. In my case, I let the car sit for a few hours, and the issue was cleared.
It has never reoccurred.
Old Nov 12, 2014 | 12:30 PM
LoneStarFRC's Avatar
LoneStarFRC
Incorrect. The crossover tube is at the very top of both tanks, not "the 3/4 level". Enclosed is a good picture of the C5 Corvette (non-FFS) tank setup from an ad on the big auction house.
The only time the siphon jet pump operates is when the main fuel pump (in the left tank) is actually operating.
Old Nov 12, 2014 | 08:43 PM
69's Avatar
69
Cruise-In VI Veteran
Hey Duhve, there are codes posted for various fuel system faults, Get ALL the codes from your DIC and post them to this thread. Once you post up the codes, we will get you pointed in the right direction
Cheers,
K
Old Nov 12, 2014 | 08:58 PM
Smoken1's Avatar
Smoken1
Entering On-Board Diagnostics perform the following steps:
1. Turn ON the ignition switch, with the engine OFF.
2. Press the RESET button to acknowledge any warning messages present.
3. Press the OPTIONS button on the Driver Information Center (DIC) and hold.
4. While holding the OPTIONS button press the FUEL button 4 times within a 5 second period.
5. System will first enter automatic display mode followed by the manual display mode.
Manual Display DTC Mode:
DIC Button Function When In Manual Mode
1. FUEL Previous DTC
2. GAGES Next DTC
3. TRIP Previous System
4. OPTIONS Next System
5. E/M Exit Diagnostics
6. RESET Clear DTCs
Old Nov 17, 2014 | 11:31 AM
drseth's Avatar
drseth
Default My Fix
Hi,
I had the same problem with my 2001 C5, with 59K miles. After fill up, it would only go up to 7/8 full, then after about 100 miles, the gauge would go to zero, with an idiot light coming on. After resetting the code, sometimes it would come on again with 3/8 tank, with same codes.
I took it to the dealer, and they said I needed to bring it in with the gauge on empty and the CEL on. They have a scanner that is more specific. They said I needed a new right side sender, which they quoted at $1200.
Instead, I tried the Techron therapy several times, with no success, so I ordered the part on Amazon, and did it myself. In 1997-2003 C5's, the sender can be replaced without dropping the tank. All you have to do is remove the RR wheel, and it is mounted on the side of the tank, in the fender well. It took me an hour to replace.
No lights ever since.
Hope that helps.
Old Nov 17, 2014 | 09:49 PM
lectroglide's Avatar
lectroglide
what do you mean 2nd 3rd generation?
Old Nov 18, 2014 | 04:15 PM
Bluemill's Avatar
Bluemill
Default That's good news Doc!
If, or should I say, when, the sender does really go it's nice to know you don't have to go nuts with dropping the whole rear axle assembly, etc. I'm up at 102,000 miles so anything is inevitable!
Enjoy your rides!
Bluemill
Old Nov 18, 2014 | 09:26 PM
rodsvet's Avatar
rodsvet
Riversidedan1, I was referring to the two types of fuel systems used in the C5. The first 6 1/2 years they used a tank system that was easily accessible for changing/cleaning the pumps. After that the C5 used a fuel system that required dropping the tanks to get at the pumps and sensors. Maybe I should have said "first or second type" instead of generation. Rod
To Fuel Gage on EMPTY
