Ground Point(s) for RF Unit
Old Nov 11, 2014 | 02:34 PM
Corvette_Ed's Avatar
Corvette_Ed
Default Ground Point(s) for RF Unit
I keep getting the same codes popping up for the BO RFA (U1016, U1064, & U1096) and want to check the ground(s) for the RF actuator. Does anyone happen to know which ground point(s) are connected to the unit?
Old Nov 11, 2014 | 05:26 PM
dadaroo's Avatar
dadaroo
G104. Why don't you check the voltage and ground from the actual RFA?
Old Nov 11, 2014 | 06:11 PM
Corvette_Ed
Thank you. That ground is one of the few that I haven't gotten to yet for cleaning so I figured I'd just kill two birds with one stone. I'm hoping it's the ground, but I have a feeling the codes are popping up because of my aftermarket alarm & key fobs. Nothing ever stops working; the codes just keep popping up at random times and it's always the same three.
Old Nov 11, 2014 | 08:59 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by Corvette_Ed
............Nothing ever stops working; the codes just keep popping up at random times and it's always the same three.
Though annoying maybe, any code with a "U" prefix (meaning communication), that also has a "H" suffix and for which there is no actual system malfunction, can be ignored.
Straight from the FSM.
Old Nov 12, 2014 | 09:23 AM
Corvette_Ed
That's good to know, thanks. If cleaning the grounds doesn't make them stop appearing I'll just write it off as a harmless glitch and move on to the next part of my project.
Old Nov 12, 2014 | 12:10 PM
LoneStarFRC
I used to get those damned things so often I actually started remembering the code numbers
1016
1056
1064
1096
I strongly suspect this is but ONE of the reasons GM decided to do away completely with an owner/operator being able to directly read/reset DTC codes in both the C6 cars as well as the C7s.
Far too much confusion and "complaints" creating a huge waste of time and money both at the dealer level and the factory level as well. It was a "good idea" but essentially a case of TMI.
Old Nov 12, 2014 | 12:29 PM
Corvette_Ed
It's a perfect addition for someone like myself who can't afford to take the car to the dealer every time something isn't working correctly. Being able to self-diagnose has saved me thousands and enables me to own a C5 on a retirement budget because I can do my own repairs.
Old Nov 12, 2014 | 12:42 PM
LoneStarFRC
I agree with you completely and I too have benefited from having this system.
We, however, are "car guys" ready and willing to be able to perform hands-on repair and/or diagnoses along WITH the use of the appropriate Factory Service Manual. The vast majority of Corvette owners do not have the time, expertise, or ability to use the system to it's full advantage and to them it creates much confusion and false information floating around out there, ESPECIALLY in the secondary market. The myth, or false assumption, that pushing the "RESET" button on the DIC "fixes" the problem is but one example of what I'm speaking of.
Old Nov 12, 2014 | 04:51 PM
Corvette_Ed
Oh, if only it was really that easy.
Old Nov 12, 2014 | 08:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,, I learn a lot from ANY DTC that pops up. The DTCs U are usually ignored. They are sometimes caused by a LOW VOLTAGE issue.
Be it a weak battery, poor connection, bad ground or dirty ignition switch, something is causing that / those U series DTCs to trip.
If it were me, I would do this:
1. Have the battery fully tested. Check Reserve Capicity & CCA.
2. Put a DC Volt Meter directly on the battery terminals. Have an assistant cold crank the engine and observe the meter and see how far the voltage drops below 12 VDC.
3. Find the RFA Module fuse. Use the meter and measure the two test points on top of the fuse to CHASSIS GROUND and see what voltage you have when you turn the ignition ON and after you crank the engine. If the voltage ever drops below the module voltage threshold, it will shut down for a microsecond and throw a comms code.
4. The ground for that is G104 BUT,,, it also goes through Splice Pack SP 208. Its a good idea if everything checks out, go to the module and read voltage and ground there.
Bill
To Ground Point(s) for RF Unit
