Got a dyno tune with LS1 Edit today...
Old Aug 2, 2002 | 08:57 PM
Crushinator's Avatar
Crushinator
Default Got a dyno tune with LS1 Edit today...
The basline dyno run we did on the car was 30hp less than the last time I had it done. It was hotter then hell today! My outside temperature reading in the car was 106 degrees when I left the shop! The last time I had it done it was 80 degrees. Anyway, he got the horsepower back up to where it was before, so basically I gained 30 horsepower from the tune! The best news is that I gained 40 peak rwtq! I wasn't too concerned with the peak numbers, but more concerned with the power loss I was getting from 4,400 RPM to about 5,600. After the LS1 edit, I gained 60 rwtq at 5,200 RPM! That's a difference I should really feel! Now the hp and torque curves are both very smooth. Before if you remember they were both very choppy. My Air/Fuel ratio is now up to 12.3:1 and I have zero knock retard! I can't wait for a cool night to take it out and run it so I can feel the difference. It was just too darn hot today to beat it too bad. I'm a firm believer in LS1 edit after today. Just so long as the person doing it, knows what they're doing. I just wish it would've been cool outside so i could post some impressive numbers.
Old Aug 2, 2002 | 09:00 PM
bparker's Avatar
bparker
Default Re: Got a dyno tune with LS1 Edit today... (QuickSilver97)
:cheers:
Looks like LS1Edit is paying off for you guys! :D
Old Aug 2, 2002 | 09:03 PM
Crushinator
Oops, forgot the numbers... :crazy:
Date: 7/6/2002
Max Power 416.1 Max Torque 390.3 Temp 80 degrees
Date:8/2/2002 (Baseline run)
Max Power 387.9 Max Torque 371.5 Temp about 100 degrees
Date: 8/2/2002 (final run)
Max Power 416.6 Max Torque 411.5 Same temp
These are SAE corrected numbers
Old Aug 3, 2002 | 01:01 AM
Dave68's Avatar
Dave68
...very impressive numbers! :cheers:
Old Aug 3, 2002 | 08:07 AM
Greenbeast's Avatar
Greenbeast
Congra...
Old Aug 3, 2002 | 09:49 AM
batsallover's Avatar
batsallover
:cheers:
Very impressive. :yesnod:
Old Aug 3, 2002 | 10:10 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Got a dyno tune with LS1 Edit today... (batsallover)
:cheers: :cheers: :cheers: ;)
To Got a dyno tune with LS1 Edit today...
