upgrades
Old Dec 6, 2014 | 11:35 PM
metalheadbusa's Avatar
metalheadbusa
Default upgrades
Hey guys. i would like to do something a little different to my 99 c5. has anyone put in a push button ignition in a c5? if so where did you get the kit to do that?
Old Dec 7, 2014 | 09:45 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
It's a $25,000-$50,000 upgrade. It's called a used C6.
All kidding aside, I have never heard of anyone doing this and it would be more involved than you might think.
Old Dec 8, 2014 | 07:02 PM
ghouse78's Avatar
ghouse78
2nd Gear
should be an easy electrical job if you think about it
get a wiring diagram or find the right wire that leads to the starter, cut it and splice your wire going to and from new starter button.
you push the button, it completes the circuit and starts your car.
Of course i am sure there is something more complex about it if no one else has done it before.
Old Dec 8, 2014 | 07:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!! The SECURITY stuff and the Column lock will be the WALL... Its not difficult but,, its also NOT easy..
I agreee,,,,, C6 up-grade.
BC
Old Dec 8, 2014 | 08:21 PM
4DRUSH's Avatar
4DRUSH
If you have the key on, a push button should be able to preform the starting sequence.........yes, no ?
Old Dec 8, 2014 | 08:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES! LOL,,, I can do it with a payer clip. Just connect the RED and PURPLE wires on the THEFT DETERRENT REELAY..
Old Dec 8, 2014 | 09:08 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
On a c6 a6 if you push the button with the brake depressed the engine will start. If you push it with the engine running the engine will shut off. If the engine is off and the brake is not depressed and you push the button the ignition will turn on. Unless someone is making a conversion kit it will take some creativity to make the c5 a push button like the c6.
Old Dec 8, 2014 | 09:30 PM
4DRUSH's Avatar
4DRUSH
Well yea, just like a C6 would be difficult, but for the cool factor of pressing a button vs turning a key would be easy
To upgrades
