Clutch problem after H/C
Old Dec 8, 2014 | 01:30 PM
harry_ss's Avatar
harry_ss
Default Clutch problem after H/C
After h/c install ive been having clutch problems in my c5z..it sticks to the floor.
I used the search buttom and found many users with the same problem as me.
Some users do the "drill mod", others say just keep the brake fluid as clean as posible and other solution could be the Tick master cylinder.
Why im having this issue after h/c install??
What is the best solution for this?
thanks in advance for your help
Old Dec 8, 2014 | 01:34 PM
zeevette's Avatar
zeevette
With the added power, the stock clutch is overmatched, so install a good aftermarket clutch, and new GM hydraulic slave, and master cylinder, and call it a day. That other crap only works temporarily, or not at all.
Old Dec 8, 2014 | 01:51 PM
Stroker87's Avatar
Stroker87
i had the same problem on a z28 after I up'd the HP stock clutch would get hot and I'd loose the peddle till it cooled (less then a minute usually)
Old Dec 8, 2014 | 02:56 PM
Cheesecake 07's Avatar
Cheesecake 07
+3...dont waste time on money on those myths. You need an aftermarket clutch. Sucks...H/C feels great when you can bang gears though 💪😃
Old Dec 8, 2014 | 03:13 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
What clutch do you currently have? What other mods do you have? The issue with C5 clutch hydraulics is well know. I personally change my fluid 1-2 times a year or more if I track the car. The clutch lines are not far from exhaust heat sources in the c5 plus the slave is by the engine, that all contributes to contamination and break down of the fluid. Keeping it fresh and changed frequently is a must for proper operation. While I have aftermarket clutches I have not had an issue from day one with keeping the fluid fresh. One of the best mods would be a remote clutch bleeder so this becomes a very easy task.
Old Dec 8, 2014 | 03:18 PM
harry_ss's Avatar
harry_ss
The clutch is not slipping. I read that some users still have issues after installing an aftermarket clutch.
Old Dec 8, 2014 | 03:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,,, I did the heads cam thing and as soon as I did my very FIRST full power run, I had the same issue.
LESSONS LEARNED: When I removed the old clutch, I figured it would have been fried... My 02 Z only had 55K miles. The old clutch looked fine! Nothing visually abnormal.
HOWEVER,, when I disassembled the master cyl, the inside of the master cyl was full of nasty clutch dust goop.
SO,, you can try this first:
Install a NEW, GM OEM slave Cyl and see if that solves your issue. If not, you will need a new one anyway.
I have 450 RWHP so, I went over board and installed a SPEC Twin disk.
Bill
Old Dec 8, 2014 | 09:25 PM
Cheesecake 07
Its not slipping thats the issue. The stock pressure plate doesnt have enough "spring" to release under the extra load your giving it. Which is why your pedal is on the floor after letting it rip and why it does not happen under normal driving.
If your fluid is black, pedal feels funny/sticks under normal driving or car is leaking brake fluid from the bellhousing area...its possible your hydraulics are done. Otherwise if you keep researching it'll become pretty clear you need a clutch. Its your car...but I chased these demons down doing all the suggested things, not one made the slightest improvement and drove me nuts in the process. Mantic ER2 installed. Problem solved. At 460rwhp...best $750 i spent so far.
Old Dec 8, 2014 | 10:02 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If,,,,,,,,,,,,,,,, You were like me (after thought) and found EVERYTHING to be normal after a clutch swap) you will kick you self in the *** wondering if the MASTER CYL change would have resolved your issue AND allowed you to have an additional 30-40K miles on your OEM clutch!
martysauto's Avatar
martysauto
St. Jude Donor '14
Harry, I suggest you follow the above recommendations. I built my car all as one project, all bolt ons h/c and a monster level 2 clutch. I have shifted it repeatedly at 6800 rpm's with no problems. Save yourself the aggravation and just do it.
Old Dec 9, 2014 | 12:27 AM
StingrayRebel's Avatar
StingrayRebel
I agree, the stock clutch is just junk, period... I tried a complete fluid flush, expensive fluids, and a tick master which helped a little but didn't completely cure it... swapped to a twin disc and it shifts like butter now
Old Dec 9, 2014 | 10:47 AM
Stroker87's Avatar
Stroker87
your problem is probably the clutch fluid over heating (brake fluid) if you have headers, you can try to flush the old fluid out, use heat wrap on the clutch fluid lines and check to see that the line are not real close to the exhaust (i had one touching) all this might get you by for a little while but in the end your going to change the clutch from wear since the new HP is going to kill it
I had this same problem and installed a tick master adj master, new gm slave & monster stave 2 clutch and have been very pleased (knock on wood) no problems
Old Dec 9, 2014 | 12:29 PM
harry_ss's Avatar
harry_ss
Yes i have long tube headers.. i think i will wrap the lines and maybe the drill mod.
I will change the clutch and the slave cylinder but not now...
Old Dec 10, 2014 | 08:42 PM
silver408z's Avatar
silver408z
I had this problem when I was bolt ons and cam. Put a clutch and slave cylinder in and it was perfect. The slave cant be changed without taking the torque tube out. I personally put a new slave in every time I do a clutch. They cost like $120 and it would cost a lot more to take the driveline back out to replace just a slave.
My vote would be to replace the clutch, slave and add a remote bleeder. Also make sure all new fluid goes in.
To Clutch problem after H/C
