Varmints chew wiring harness
Old Dec 12, 2014 | 09:45 AM
RockinRita's Avatar
RockinRita
Default Varmints chew wiring harness
Who knew??? $1150 later, I now have mothballs in a stocking under the hood to prevent this again! Varmints.
Old Dec 12, 2014 | 09:57 AM
4DRUSH's Avatar
4DRUSH
Mothballs sound like a good idea, it's just a pain prying their little legs apart
Old Dec 12, 2014 | 10:04 AM
RockinRita's Avatar
RockinRita
Goober!
Old Dec 14, 2014 | 02:50 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
There you go....the OP (a relatively new member to CF, no less) has a serious issue, and you try to yuk it up!!
Old Dec 16, 2014 | 01:50 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
I have been reading on the CF that a lot members are using Irish Spring soap..Put some in a cup or bowl under the hood and some scrapping's under the Vette..Also put some (small chunks) under the wheels.. Just put mine away,(we'll see?) but will be taking it out from time too time for an occasional exercising ..Hope IT works.
Old Dec 16, 2014 | 02:42 PM
Joe_A's Avatar
Joe_A
St Jude Donor '15
WOW that is bad..... they actually ate through the copper.
$1150 to repair did u put in an insurance claim or eat the cost ?
Might want to consider some snap traps in the garage in addition to the moth *****
and maybe add some dryer sheets.
Old Dec 16, 2014 | 04:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Moth ***** EVAPORATE very quickly out in the open air.
SO,,,,,,,,,,,, If you want the continued use of Moth *****, you should check them frequently to make sure they are not all gone and you have mice again..
Been there done that!
If you want a good effective FREE mouse trap, Check out this U Tube vid!!
Make sure to put some antifreeze in the water if you have a NON Heated garage/storage space.
Bill
PS
They LOVE to nest in the HVAC FAN!
GOT the little BASTARD!
Old Dec 16, 2014 | 04:46 PM
Joe_A's Avatar
Joe_A
St Jude Donor '15
[QUOTE=Bill Curlee;1588499802]Moth ***** EVAPORATE very quickly out in the open air.
Bill
PS
Bill
I like the bucket trap.
Have u tried it ?
Old Dec 16, 2014 | 05:01 PM
RockinRita's Avatar
RockinRita
I ate the cost...too much paperwork. I put dryer sheets under the hood...will try the Irish Spring soap!
Thank you everyone for the suggestions!
Old Dec 16, 2014 | 05:56 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Joe
Works as advertised!! They were dieing to take a ride!
To Varmints chew wiring harness
