I went with the Moroso HD oil accumulator for this build... Looks like a very nice unit with screw in end caps.
And all the hardware: hoses and a custom fitting to screw into the block with ports for the accumulator and extra 1/8NPT ports, an adjustable oil pressure light set at 40 psi, 2 x pressure gauges - 1 for the charge side so I can keep an eye on how much reserve I have and 1 for actual oil pressure.
Ls6 oil pan with a Texas Speed ported Ls6 oil pump...
Mock up of the drain lines. I will be using stainless braided lines and 1in longer fittings at the heads to move away from the head ports... Note the custom 3 into 1 manifold👍
CNC Motorsports all forged 408
Eagle Crankshaft and rods
Diamond 11540 forged flat top pistons
Compression 11.7:1
AFR 230 72cc heads milled to 67cc (reduces compression to 11.5)
Morel Lifters
Jessel rockers
Smith Brothers restricted flow push rods .040 oil
Drilled lifter trays
Brian Tooley Stage IV Cam 235/242 .620/.593 -3& on 111 separation
Fast 102 with a Nick Williams 102 Throttle body
1 3/4 Dynamax Headers, X pipe, & Borlas
The car makes 525 rwhp so I would think you would be very close to this.
Make sure you use the restricted push rods and drill the lifter trays.
Got it thanks. That is a strong build!
Any more options other than Comp cam High Tech and Smith Brothers for those pushrods? One of the local engine builders here mentioned another name but I can't remember it now...
I am also running 6 (3 per head) external oil drain lines.
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
We made 511 RWHP with 22X/22X 112 LSA cam. Bone stock LS3 heads with upgraded valve springs and RKT Performance ported stock LS3 intake and LS2 TB. You should be over 500.
[QUOTE=Z06VENOM;1589095302]Got it thanks. That is a strong build!
Those are the only two that I'm familiar with too.
Great, and I thought my cam was small!
Must be your intake porting. Pm me some more info on that please.
SWEET! Oh I wish.
Yeah I hope this will deal with the LS3 oiling problems. With under $500 and a few hrs of machining invested in this I can alsways go dry sump later, figured this is worth a shot👍
All ready to go in.
A few questions on the tuning/wiring.
1. Will my Bosh 36# injector tables work for the LS3 injectors?
2. What about the fuel return setup? Do I just block off the return fuel line and leave that little plug hanging? What if any do I need for the fuel system?
3. Ls2 Throttle body... Any programming needed to run?
