Do the MOMO shift knobs rattle?
Old Aug 9, 2002 | 01:38 PM
Tracy's Avatar
Tracy
Default Do the MOMO shift ***** rattle?
I've gotten my Hurst quieted down with no **** on it, but the stock **** is now the buzzzzzzz point. I suspect it's the shift pattern insert piece. So...I'm looking at *****--the MGW, Kirban's big aluminum **** and the MOMOs. I know the big solid aluminums don't rattle.
Specifically, I'm looking for buzz/rattle experience with the MOMO Phantom, Combat or F16.
Old Aug 9, 2002 | 01:43 PM
Cya5's Avatar
Cya5
Default Re: Do the MOMO shift ***** rattle? (tracy)
No not at all.
Old Aug 9, 2002 | 02:20 PM
chrislee2's Avatar
chrislee2
Cruise-In II Veteran
Cruise-In V Veteran
My momo combat **** does not rattle in the least.
Chris
Old Aug 9, 2002 | 02:48 PM
The DBK's Avatar
The DBK
Mine rattled like a beotch, then I tightend it down to the breaking point and the rattling stopped....the whole **** just slid right off after that... :rolleyes: :lol: :mad
Old Aug 9, 2002 | 03:36 PM
Tracy's Avatar
Tracy
Default Re: Do the MOMO shift ***** rattle? (The DBK)
DBK--
Could you elaborate a little bit? Which model, and did you really rip the **** off? :eek:
Old Aug 9, 2002 | 04:09 PM
ddawson's Avatar
ddawson
My RaceAir dosn't rattle at all. The orginal **** did when under heavy throttle.
Old Aug 9, 2002 | 04:47 PM
dba4life's Avatar
dba4life
Default Re: Do the MOMO shift ***** rattle? (ddawson)
I have the race air leather momo **** and a hurst and it does not rattle at all.
Old Aug 9, 2002 | 11:45 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: Do the MOMO shift ***** rattle? (dba4life)
I have the Combat Silver Momo...no rattle whatsoever! :smash:
Old Aug 9, 2002 | 11:48 PM
chadwick's Avatar
chadwick
ditto
Old Aug 10, 2002 | 12:14 AM
levettegrl's Avatar
levettegrl
Cruise-In IV Veteran
Default Re: Do the MOMO shift ***** rattle? (C5 StockSwap)
DITTO!
Old Aug 10, 2002 | 12:33 AM
nassau99's Avatar
nassau99
Default Re: Do the MOMO shift ***** rattle? (levettegrl)
combat/hurst=NO MORE RATTLE= YIPPEE :yesnod:
Old Aug 10, 2002 | 12:55 AM
ambitin's Avatar
ambitin
Default Re: Do the MOMO shift ***** rattle? (nassau99)
Mine doesn't make a peep. I did have to loctite the biatch to keep it from shaking itself loose every few weeks but since using the loctite it hasn't become lose even one time! I'm using a ripper.
Good luck,
Justin
Old Aug 10, 2002 | 12:56 AM
JWSchmidt3's Avatar
JWSchmidt3
None of mine have. :cheers:
Old Aug 10, 2002 | 02:19 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: Do the MOMO shift ***** rattle? (JWSchmidt3)
I've got the Mojo Combat Kanob on the stock shifter.
No rattle at all. It's just got a couple of set screws to hold it in position.
Old Aug 10, 2002 | 08:57 AM
AFVETTE's Avatar
AFVETTE
Mine did, just installed the new MGW Gripper and the Hurst doesn't rattle anymore.
Tom
USAF Retired
Old Aug 12, 2002 | 12:53 PM
Tracy's Avatar
Tracy
Default Re: Do the MOMO shift ***** rattle? (AFVETTE)
Excellent info, guys.
Does anyone with the MGW get "hand burn" due to heat transfer from the tunnel/shifter? (and I don't mean typical hot car on a summer day heat, I mean heat from the tranny tube area)
Momo Combat or MGW...Momo Combat or MGW? Hmmmmm...
Old Aug 12, 2002 | 07:07 PM
Tracy's Avatar
Tracy
I just orderd the MGW "Gripper" model. It certainly is a high precision piece, especially made for the C5 stick/threads, with a 1/4 inch set screw in the 12 o'clock position to fully clamp and thus jamb the threads onto the shaft. This should eliminate that last little bit of rattle after installing the Hurst.
I was dismayed to find out that MOMO ***** are a "one size fits all" item and decided to go with case-specific design.
To Do the MOMO shift knobs rattle?
Old Aug 12, 2002 | 08:01 PM
jimman's Avatar
jimman
Tried two Momo's both rattled, one looked like the silver and black as pictured in this thread. I had the dealer that sells the ***** go with me so I didn't have to shell out 90 bucks or so. He said it was a waste of time but knock myself out. Also added 5 oz of wheel weights and still rattles. It's ratteling in the pivot mechinisam and gets applified by the shaft and ****. Some will do it and some will not, that simple.
Old Aug 12, 2002 | 09:20 PM
ace's Avatar
ace
I was worried about this myself, but took the chance since Momo made the only **** I seemed to like. No rattles here....... If you have issues with your MGW, give Momo a try.
Old Aug 13, 2002 | 12:39 PM
AFVETTE's Avatar
AFVETTE
Tracy - The **** gets WARM but has never been too hot to touch and I have the glass top in a daily driver here in St Louis. I like the fact that the MGW sits even lower then the OEM **** by 3/4 of an inch. I had the momo F16 and the MGW sit's about 2 inches lower. I have over 200 miles on the MGW and it's TIGHT.
Try and find a better **** for $45 **** out there. I couldn't and was ready to go back to the OEM shifter the Hurst rattled so bad. I'm a very happy camper now. And I never would have thought that you could lower the Hurst even more and make it feel better.
Tom
USAF Retired
