I am picking up a 99 frc on monday and when i was test driving it yesterday i noticed the hud randomly changes from mph to kph and back. anybody know what might be the cause?
How could that be??? If the E/M switch were stuck then I would expect the other items on the dash that have E or M values to be changing as well and more or less in step with the HUD display changing.
I agree! If the IPC isn't flip flopping between the two the button cant be stuck
What happens if you use the English / Metric button and put it in METRIC. See if it still flip flops between the two.
When the HUD reads METRIC, is the IPC reading ENGLISH? When you intentionally press the E/M button, does the HUD properly change?
I did press the e/m button and it would change accordingly. I did not notice other values changing but i wasnt looking for them either, i was just looking at the speed. The car will be here tomorrow afternoon and I will have a little more time to play with it.
Yes the HUD works fine and displays in mph and I can change the right side of the hud to read fuel or oil and temp. None of the buttons on the right side if the wheel work now.
I would disassemble the IPC and make sure that all the connectors for the HUD and BUTTONS are properly connected. Do that before you throw parts at it. If all the connectors are properly connected,
You may just need a new button module.
